I work at Aspley Maccas doing the graveyard shifts. I see alot of strange things to say the least, i saw a N14 pulsar throw massive smoke the other night leaving the car park, but today took the cake.
I opened the back door to go home this morning and what do i see? A massive falcon club cruise. About 20-30 of them, mostly XY's and XR turbos.
https://www.sau.com.au/forums/topic/59736-what-the-hell/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
