I have 6 x RX& 550 cc injectors, cleaned about 15000ks ago, been in car since. Plugs modified to fit up to rb20 injector plugs. High Impedence, pink top.
Will have them out of the engine tomorrow all going well and will get a photo if anyone wants to see em.
$350
Cheers
Dave
https://www.sau.com.au/forums/topic/59832-6-x-rx7-550s/
will it fit RB25 ?? is it top feed??
$350
Cheers
Dave
https://www.sau.com.au/forums/topic/59832-6-x-rx7-550s/#findComment-1140724
Sorry i took so long, i've been away for a few days.
JL, I'll try and get ahold of a camera and get pics up in the next couple of days, stupid bastard that i am i left my camera at work. Hopefully have something up on Monday.
fire_bringer_, They wont drop into an RB25. I've just upgraded to an rb25 myself which is why i am selling them.
Cheers,
Dave
https://www.sau.com.au/forums/topic/59832-6-x-rx7-550s/#findComment-1142148
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
