Hi all,
well overheat or heating issue shouln't have happen but last night my GTR heat up a bit, spit coolant out....
Took a look this morning and found that my coolant is so dirty, i will give it a FLUSH but i've notice that the Aircon fan MEANT to WORK as a secondary/back up fan when things heat up ( Well that what i've found on my old 33 ) but my didn't kick in last night .
So, i'll get Nissan dealer ( Ferntry Gully one ) to have a look but i would like to find out anyone here runs THERMAL FAN on their GTRs? If you do, how did it go? What sensor do you use....ect..? :headspin:
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/
oh by the way....i have a set of fans from a EL falcon fitted.....i wired them up through a VDO sensor that is adjustable and it piggy backs on the sender so no extra probes need to be fitted....however the fan is on for the first minute or so when the vehicle is stone cold...this is because the sender is out of the range that the sensor can see....but after a minute it comes online....
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142143
the fan is supposed to work when you got the aircon on only......make sure your clutch fan is working correctly and the coolant system has been bled correctly
Bled properly!! How and what need to be done? Do i need to give it to a radiator place to get this pressurise whatever they reckon that will flush everything out ? Clutch fan seem to be fine.
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142144
So the fan dont' kick in until a minute after you start the car? That should be fine anyway shouln't it? I don't really want to get rid of the clutch fan until i have no other option.
Does your thermal fan draw alot of power when they kick in?
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142149
Actually the fan is switched on by a coolant temp sensor in the bottom tank of the radiator on R32 GTR's - mine has it.
So when you switch the A/C on does it fire up?
west------>however the fan is on for the first minute or so when the vehicle is stone cold...this is because the sender is out of the range that the sensor can see....but after a minute it comes online....and the fan switchs off
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142171
Ok did a little test today....bypass this plug by puting a current through the FAN came on..
So the fan came on with the two terminals shorted (joined) in the green connector shown in that photo ?? If so, then problem is with the thermoswitch in the bottom of the radiator.
But I'd recommend get your entire cooling system checked out.
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142427
...so i assume that this plug here, which plug into the radiator stuff itself up therefor there were no signal/current sends to the condensor fan .....
What you guys think? I'll order a new one from Nissan?
Before you order a new one you can check out the old one if you have access to an ohm meter. With it out of the car as shown, the resistance across its terminals should be infinate at anything less than about 90C. Next thing to do is to chuck it in some boiling water (eg pan on a stove), let it sit for a minute to reach temp and then quickly take it out and measure the resistance of the terminals before the temp drops. Resistance should be zero or nearly so. If not, it's stuffed. If it checks out OK with this test, it's time to look at the wiring (corrosion, etc).
Of course don't burn yourself in the process :cheers:
Oh and if you don't have an ohm/volt meter I'd recommend getting one as they are'nt expensive and are a very useful tool.
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142434
Of course don't burn yourself in the process :)
Ok thank heaps Steve, sound a bit technical as i don't have a ohm meter so i might get an electrical cleaner spray to clean out all the corrosion tomorrow .
If it still doesn't work by then i'll book it in for a radiator flush also order a new thermal switch or just give it to Nissan get the whole thing check out. :cheers:
https://www.sau.com.au/forums/topic/60019-gtr-heat-issue/#findComment-1142441
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
