I am going to be doing a few things to my R32 GTST very soon including a full respray. I am a little torn on which colour to go for, but I have narrowed it down to 3 choices.
All of these colours are HOT and I would be happy with all of them. I am at the point where I am trying to think which would be the best colour for resale...
R33 GTR v-Spec Purple (LV4)
I love this colour... However, it doesn't look that great when it's not out in the sun and will probably show paint swirls and scratches alot more... It's not as "Look at Me" as the other 2 either....
R34GTR BaySide Blue
Classic colour... I love it. Look so good when it's clean.
Holden SS Green
Very cool colour. I will probably be getting these rims too.
This is a new one... Looks custom
https://www.sau.com.au/forums/topic/60053-which-colour-for-my-r32/
  • Replies 45
I like the bayside blue, in terms of resale.... it's hard to say what will make you more money unless you mean which colour will show up scrathes then probably all three of them won't be very good for that purpose, but yeah the bayside blue is a nice!
btw, on the SS green car, are they IS200 rims??
The blue or purple, I have a V-Spec R33 in that colour. Looks awesome, although is very hard to keep clean and the colour looks quite dull if not kept sparkling.
Why would you want to paint a skyline in a commodore colour, in my opinion it looks very common - especially with every second SS and commodore station wagon etc in that colour. I reckon it will be a very dated colour in a few years time. I remember when the SS commodores starting coming out in the tiger (gold) colour everyone reckonded it looked shit hot, now just looks shit. (In my opinion!)
That was my concern, and to be honest I think it's already getting that way.
I would really love to have the purple but want it to look hot 24/7. The photo posted above of the Purple R32 is a custom colour. The guy who owns it wont disclose the paint code at the request of the painter....
Yeah sorry. Should have mentioned that earlier before people got a bit excited.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
