I don't think the owner is on here but I have seen it around a lot lately.
Looks tough, I'm a bit fan of that kit, but at a small price of $30,000 (IIRC) I think I'd rather make my car go faster than look pretty :D
I'm pretty sure that's one of the ones that Ernie from Skyline Imports did.
https://www.sau.com.au/forums/topic/60094-fat33-skyline/#findComment-1143027
Yeap, one of the first ones Ernie had made. Nice looking car. I'm pretty sure $30k was roll in roll out? eg; for that price you get a kakimoto wide body back, painted and with rims?
If any ones interested Kakimoto found out, and his longer allowed to flog the kit off. If his still selling it, its news to me.
https://www.sau.com.au/forums/topic/60094-fat33-skyline/#findComment-1143084
does he live around the browns plains area?? i saw him a few times out that way, unless it was another red 33 with a wide body kit
i have also seen him around the browns plains area..grand plaza actually
https://www.sau.com.au/forums/topic/60094-fat33-skyline/#findComment-1150384
he lives at new bieth thats near greenbank and yes its still up 4 sale and yes he gets around browns plains i also live at browns plains as 4 cairns his mother and father in laws live up there and whe was visiting there . the car is 4 sale for bo ut $49,000
https://www.sau.com.au/forums/topic/60094-fat33-skyline/#findComment-1159532
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
