hi everyone,
i need help with an engine conversion, i am tryin to gather parts, can someone tell me if i am on the right track and if i am missing parts.
Atm i got a non turbo so i am buyin a
RB25DET head and fittin it onto the non turbo bottom, apparantly they have same bottom.
Exhaust mainifold
*Inlet mainifold im not sure if i need it, i was told i did
Intercooler
ECU
Wiring loom
thanx heaps
hate to jump on the bandwagon - but considering there is only about 3-5k difference on a turbo, and non-turbo r33, just sell the car..buy turbo version. It will cost more than $3-5k to convert it, and nobody will want to buy it afterwards.
Your car can be "converted" in a couple of short weeks!
his right its like changing a bettle into a porsche, its still a bettle, when you would rather have the porsche
alot comes with it engine changes i was going to do this to my old r31, but i looked up prices think about it
engine
brakes
lots of custom work
FMIC
boost controllers (if you want more power and ya do)
my mate bought my old r31 including buying it and changing everything over cost him 15-16k took him a year to get the car running right then he rolled it lost 16k outrught was never insured
the money i got from old car i pick up an r33 gts-t for 17k and i was driving it two weeks after i sold my old car and the old r31 could never handle like an r33
what im saying is buy something that is built to do what u want, its cheaper and usually more reliable
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
