Hey guys, my brother's car is up for sale. It's a white 1993 R32 Type M model. Details are as follows:
Engine
- RB20DET
- Has done a total 92,000KMs
- Rebuilt Motor
- Forged Pistons
- Aftermarket In-tank fuel pump
- Overhauled and Blueprinted ($8,500 worth, with receipts)
- HKS mushroom pod filter
- 5Zigen Full Exhaust with 3inch piping
- Hi-flow cat
- Trust Front-mount Intercooler
- Hi-flowed turbo, no shaft play
- Turbo timer
- Has run stock boost since engine overhaul
- Just upgraded to turbo from an RB25DET engine yesterday
Exterior
- Full Respray @ DT Panels in 2pak paint 5 months ago
- GTR Frontbar
- Type M Sideskirts
- Type M Rear Pods
- Slight scuff above left rear wheel
Interior
- GTR seats
- JVC head unit
- Nismo aluminium gearknob
- Cracked centre dash vent
Suspension
- Cusco height / damper adjustable coilovers
Rolling Stock
- Stock R32 wheels powdercoated in black
- Tyres replaced with Hankook Ventus for RWC 3 months ago
Miscellaneous
- Viper alarm w/ microwave sensor
- Central locking
Pics attached:
Price: $15,500 negotiable
Regretful sale to say the least - the car has a LOT of potential, and since it was my brother's first car, boosting remained uncharted territory.
Call Vu on 0433 512 115 for further details. Car will come with RWC upon sale.
Cheers !
https://www.sau.com.au/forums/topic/60175-fs-1993-white-r32-gts-t-type-m/
  • 3 months later...
shit
i would of been very interested if it were in sydney :)
ps: can everyone put the state/capital city in the thread titles like this: [NSW] or [sYD] etc
^^ Good idea, it's done on other forums' FS section and is really convenient (stating location in title) :(
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
