Well I'm gunna have a serious go...
is it ok to remove all the pipes from the turbo to the soilernod
What solenoid? Is it stock? Or part of a boost controller? Why do you want to remove all the pipes? Pics...
as i put a boost controll on and i run it form the turbo to the wastgate
What do you run from the turbo to the wastegate? What boost controller?
and can you tell me what some cheap things to do to my motor is to make it faster
Define cheap... Whats done ATM?
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1145274
DIY: Boost Controll
Many of you may have been fooled into buying bleed valves, in some cases even expensive electronic items. All i can do is frown at this behaviour. You have all you need to make your own at your local hardware store! What your going to need for this exercise is a piece of vacumm hose, prefferably long enough to reach from your actuator to near your pod or airbox and a screw (pictured below) and a screw driver (philips head)
After obtaining these items you need to decide one of two things. Just how much boost do you wish to run and whether or not you want to be able to adjust it.
OPTION 1) Run the vacumm hose off your actuator with no screw in the end. This method is very effective performance wise, however it MAY lead to destuction of things such as your turbo. Not to worry fuel cut will save you. This method shows how truly hardened you are and indicates just how much boost your stock turbo can handle before literally throwing chunks of the exhaust wheel out your exhaust. Some may view this method as a little extreme even though it has proven promising on certain cars . Not to worry option 2 is for these people.
OPTION 2) This option is for the light hearted. You take your vaccum hose and bring it all the way to near the pod. You then use your screw and screwdriver to implant the screw in the hose. (seen below) The further you screw it in the less boost you will run. To get maximum performance we suggest road tuning, to optimise the boost level.
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1145330
what are we looking at in the first two piccies??
am i correct in assuming it's the vacuum hose coming off the actuator??
i hope no-one has done this to their cars. seems seriously dodgy to me.
lol yea, as josh said we did it to his car and it held boost suprisingly well. And his Apexi boost controller was crap and didnt work, who wants to go around on 7psi, something had to be done and this was it. Dodgy? yes. dangerous? probably. Did it work? You bet ya...:(
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1151628
interesting.
just let me know how long your engine holds up and i'll consider doing this to my car.
though i suppose it sure beats spending hundreds of $$$ on electronics that don't want to work.
I have now sold the car; I had this dodgy item on the car for around 6 months with no signs or ware and or damage.
As it was only holding 12psi.. There should be any difference between that, and 12psi on a real controller.
I had a compression check down before the new owner got the car, and all was fine. The turbo was in ok condition for a car with 140,000kay.
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1152000
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
