Can you feel the tyres skipping on tight turns?
Owww yer. On tight corners or turn at ends of streets I kick in the clutch pedal so I can roll around without the tyres shaking & sounding nasty.
If I do have a '2 way LSD' Anybody wana tell me how these work, is it some sort of mechanical torque converter which locks up the wheels the second it feels any torque.
It'll lock up the wheels if i drop the clutch when idling in the dirt & get the wheels to burn out a tad as the wheels align up to sync with each other 'lock it up'. Pretty much it's always locked, but when clutch is disengaged its not locked.
http://www.upgrademotoring.com/suspension/...art_diagram.htm
・ Two way LSD
Recommended on the rear axle for rear drive cars. Activates on both acceleration and deceleration. Recommended for those who
prefer hot driving action and big angle drift.
Yep that sounds like me. i love hot driving action... lol
What kind of LSD do skylines come stock with. 1 - Way LSDs? Race cars would use 1- Way LSDs hey?
http://www.club4ag.com/faq%20and%20tech_pa...rential_101.htm
I Think its starting to make sence now.
So it would seem i have a 2 way LSD, but a good 2 way LSD shouldn’t lock the wheels under low Torque on tight corners right? Can you adjust all or only some 2 Way Diffs to when they will start to lock up, because mine locks up way easy & isnt practical for parking.
are you sure its not fully locked? I have a full locked diff, but still only get the shudder under power (clutch not depressed) on tight turns. Sounds like you have the same thing. 3 point turns and car parks are the worst.
Nar it couldnt be full locked because the wheels are able to spin independently when the clutch is disengaged. From my understanding that would give no power to the final pinion 'no acceleration or deceleration’ so no torque to move the cam which locks the diff through its clutches? I'm just going off this page http://www.club4ag.com/faq%20and%20tech_pa...rential_101.htm
If it was fully locked, it wouldn’t matter whether the clutch was in or out, I'd get shudder & wheels skipping on tight corners regardless.
It would be a two way. A full locker you would know about, if the car doesnt have power on tight turns it pretty much wont move, with the two way it releases and allowes the car to roll more.
BTW trust me, I can push my car, but I cant push my mates welded diff car if we want to turn it. Get 4 guys behind it however we can kinda move it.
Hahah yeh, defiantly glad i gota 2-way. All im trying to understand now is @ what amount of torque gives it enough pressure to lock it up, i'd love it if it would lock up at say 100 Nm +. Then I'd fine for parking & easy cornering. Is there anything I can do about it locking so easily? Maybe it's bloody set up for drift or is a drift LSD or something because coz its pretty much locked full time when the final pinion is delivering any torque when the clutch is engaged.
Some of the more exxy diffs are adjustable, or so I've read on here. Id like to find out too, same problem as you, just mines more so scared of getting done for a "locker". I also dont know how they are adjustable, I guess you would have to be stuffing about a bit and pulling the diff apart to a certin degree.
I will have to try that on mine. See if a few friends can push it while it is on full steering lock. I am sure mine is a fully locked diff. Thats what the guy where I bought it from said. He deals with them all the time so should know. The guys at the pits when I got a yellow sticker wanted me to replace it because they thought it was locked. Maybe it is a 2 way with a very tight clutch in it :D
The other thing that happend with mine, (stupid stiff and no travel suspension) I used to get beached going up driveways. The car would go on to two wheels, so one of the rears would be in the air, and it just spun. Obviously a locker wouldnt do that, you would go up the driveway. Maybe try and test it that way?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
