My clutch is slipping under boost so I am pretty sure that i require a new one. Rang one place that quoted me $1000. This sounds a little high after reading a few threads. My car isnt running a lot of power. Only has zorst, k&n panel and 10 psi.
What sort of price should i be looking at to have a clutch supplied and fitted? the daiken heavy duty seems to be a favourite round here. i thought around the $700 mark or am i completely wrong.
Any ideas or advice much appreciated
Dick.
https://www.sau.com.au/forums/topic/60359-clutch/
Ring around mate...
i got my daikin heavy duty BUTTON installed for $650 which was a bargain...that place is now closed down...however i got a few quotes from places close tot he $750 mark
Daikin is like a brother company to exedy....my pressure plate is exedy and the clutch is daikin
https://www.sau.com.au/forums/topic/60359-clutch/#findComment-1146500
Try looking at the UAS website, they have ceramic puck clutches that i ran in my GTST, the thing lasted a little over 2 years with plenty of track work and never slipped. When the friction material was all worn out i got an Xtreme ceramic puck clutch and whislt it drives a little bit better, it slips with only 220rwkws:( Day to day driving its ok, but if i launch it hard in 1st then it will slip in 2nd, 3rd, and if you keep going it starts slipping in 4th:(
$595 exchange or $750 outright...im thinking about selling my Xtreme one and getting another one of these
https://www.sau.com.au/forums/topic/60359-clutch/#findComment-1148420
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
