Hey guys I have just had price given to me for a new turbo and power fc for $3,500
what do ppl think of this price the turbo is a gt 35/40 garret. The guys also said there is a much better computer to use now. So all in all what do ppl think.
https://www.sau.com.au/forums/topic/60542-new-turbo/
The GT3540 is a very nice turbo, and quite a good price. The problem I have read about is they only come with a 1.06 exhaust housing which is way too big for an RB25DET (more suitable for a rotary and RB30 and XR6T (the XR6T is a 3540 but with a smaller comp cover, .50 instead of .70 like you buy from Garrett).
You can get the turbo modified to a .82 exhaust housing which is alot more friendly and should start to make decent boost around 3500rpm. Do not go for any of the .6x sized exhaust housings as these are too violent coming onto boost and you will just wheelspin everywhere.
A guy off these forums fitted one on his RB25DET by the name of NisJet, it made 210rwkw on 12psi. His car has 3 inch exhaust, intercooler, power fc, fuel pump.
--- EDIT ---
Do a search for GT3540 and you will see a few people that have run them. Most that keep the large 1.06 housing have forged internals and need to rev the car to 8000rpm to make good power out of it. Also does that price include a new manifold? I think it was Roy on these forums a while ago wrote you need spacer plates to put it on the stock manifold or else the comp cover will hit, and it generates heat spots and warps the stock manifold.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148861
I would always stick to the big jap brands - Zoom or HPI did a review of a range of A/M turbos a while ago, and it was proven that the JAP brands kick asre over the 'copy' series that you can get.
Makes sense to get something that has been specifically developed for your application, you can get some real bargains second hand. Try http://www.tuneagent.com/index.aspx and http://www.upimports.com.au/UPI_Parts/ as for starters.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148963
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
