its mostly a mith that the Pit is a licensing black hole (of course depending where you go) Apparently Warwick is a no-go, but East Perth was excellent, took an RX7 over there with rock hard suspension, intake bits, massive exhaust, and while he was fairly thorough he wasn't a bastard. Was taken for a drive and given my plates.
Dont stress too much, just try East Perth and welshpool first.
blacky
https://www.sau.com.au/forums/topic/60581-over-the-pits/#findComment-1149350
Hi guys
New in these forums - a few posts in the Stagea section... about to (hopefully) take delivery of my Neo6 "family wagon" in a few weeks :D
I am buying mine from an eastern states import yard - never been registered (newly complied) - so will come off the transporter at my door - then off to the pits for inspection... anyone know if this first time registration will be any different to a transfer from another state that uve said in this thread not to worry too much about??? Its important coz I have the option of getting some parts (rims, lowering, tow-bar) fitted at the yard before it comes over - but wont do the mods til after rego if anyone knows it will be under a closer or different type of inspection coz its the first time????
Thanks
Adam
PS Also thining of getting a custom towball fitted in QLD - would the pits guys worry about it if it looked done right? Or do they need load-rating stickers etc on them legally?
https://www.sau.com.au/forums/topic/60581-over-the-pits/#findComment-1149560
if your mods are reasonable and legal i wouldnt worry 2 much . ie rims are within allowed size difference and cars not 2 low . i dont know about tow bars though .
as your interstate rego is your main form of vehical identification you will need to make sure youve got all the import / compliance paper work and proof of ownership . give the department of planning and infrastructure a call and see what they require . also some states will give you a temporary rego for interstate transfer that might help to .
but give them a call and make sure , essentially youve got to prove ownership and compliance .
in terms of inspection tho everything will be the same , its just paperwork difference .
also i got my transfer at warrick , no probs . if you got a pretty stock skyline/stagea i wouldnt worry at all
https://www.sau.com.au/forums/topic/60581-over-the-pits/#findComment-1149834
Id suggest that a first time inspection of a car thats never been regoed will be 1) more expensive (113 dollars vs 56 dollars) and more indepth as the engineering papers etc will have to be double checked.
https://www.sau.com.au/forums/topic/60581-over-the-pits/#findComment-1150076
i took my car to welshpool... there is an old guy there.. AVOID him..... my exhaust was 5db to loud and my FACTORY BOV is tooo loud....
ps.. any ideas on how to silence ure bov (we blocked it adn the wastegate is heaps louder)
https://www.sau.com.au/forums/topic/60581-over-the-pits/#findComment-1150416
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
