I was curious to see if anyone has subaru injectors on their RB26, RB20, or RB25 (converted to top feed injectors)?
My friend has them on his civic and work great. If you clip the tip off the injector they are 740cc injectors and you can pick them up for around $70-90 for a set (4 injectors).
I have an RB25DET, but will be buying a RB26 fuel rail to make it top feed. Then will be getting the subaru injectors. Just curious if anyone has done this before....
https://www.sau.com.au/forums/topic/60616-anyone-use-subaru-injectors/
I'll be interested to read more on this. Good luck and keep us posted. I'm about to fit up some toyota 440cc injectors in the Rb25. High impedence so no need to use a resistor pack.
Soo what are the dimensions of the Scooby ones? What impedence? Are any other mods required to the system to accomodate them?
They are a high impedence top feed injector. I have two friends that have done this so far on their Hondas and are having great results. The easiest way of cutting the tip off of them is to get dog nail clippers with the curved blade and apply a little pressure to them while turning it around the tip, which normally will cut them off in about 2-3 360 degree turns.
The flow rate on them are all within 1% of each other and have heard no one having problems with not having equal flow rates. Just to be safe, you can send them in and get them checked for the flow rate normally for $5 per injector.
The clips are the only issue right now, but is possible to use the subaru injector clips. You can get some .110 tab and seal them with silicone and will work perfectly fine.
Much easier to use S15 SR20det injectors for Rb25det (not Neo)
They are 448cc some people say they are 480cc
at 448cc that is a 21% increase over standard 370cc
so they should be good for approx 270rwkw.
The sr20 and rb25 use the same injectors, so there is no need for any mod's
you Must get the Manual turbo injectors, as auto injectors are still only 370cc
Manual ones are red/orange colour part number 16600 91F00
370cc are purple colour which are also in S14
I had to buy 2 sets of 4 at $300 set
I will sell the spare 2 at $150 for 2
Then someone only needs to buy 1 more set at $300 or less
You end up with a much cheaper upgrade for about $450 set of 6
No need for resistor's or top mount fuel rails
There is a set of Subaru WRX injectors for sale on nissansilvia.com.com and the question has been asked do they fit Sr20
Answer quote "I do not think so"
http://www.nissansilvia.com/forums/index.p...topic=66615&hl=
Hope this helps
Cheers Darren, but with a GTR rail there is very little to be done to fit up top feed injectors.
I measured the impedence of the Toyo injectors at 3.1 ohms so they are low impedence....not what I was told. No biggie anyway. Little bit of simple wiring.
Whats the resistance of std Rb20/25 injectors, i cant remember what mine read, woudl i be right if i said somewhere around the 12ohms.
Which brings me to my next question, surely ECUs work within an impedence window, any idea what this may be. Say in the case of GTR ECU, perhaps handle impedences between 2.0-3.5ohm? RB20/25 ECU between 9.0-12.0ohm?!?!?!?!?!
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
