Hey all,
A mate of mine and i were discussing the other day, Nitrous oxide.
He was telling me that you can run a 50 shot of nitrous and it can be beneficial to ure engine (as it cools down the pistons a bit aswell as the rest), rather than destroy it.
Im pondering possibly doing this to my own car... but would like some opinions first. Has anyone here got a nitrous setup in their car? running stock internals etc? Does anyone know roughly how much it would cost to get installed?
All info/opinions appreciated :(
https://www.sau.com.au/forums/topic/60796-nitrous/
  • Replies 52
Hey, coulda told you this before but I think I forgot to. Seen a stock Ti R31 running 50 shots down the drags with complete stock internals. He claims to have done 54 passes at that point with it and it didn't miss a beat. Got some nice low 14s which is good considering there normally people trying to pull a high 15 in stock form!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151585
NOS is the "SHIT"! :)
I run an 80hp wet shot & the HIT is better than Viagra!
When set up propperly is is a safe & effective hp gain , tho getting it right can be an absolute BIATCH..... as those who were present at my first effort will testify.
As a result of this.....only a WET shot is worth doing (wet shot is where the correct ammount of fuel is injected with the nos).
I use Geogre at ADRENALINE for all Nos related stuff.... he's seen it all.
Go the Gas :burnout:
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151729
good to hear rep003,
so how much for somthing like this? do you still find it to be safe? I have always wanted to put it on but everyone always seems to say oh but this can go wrong and that can go wrong.
Plus not too mention the pic i saw recently were the whole engine blew up of the drag car when the lines caught fire! the whole bonnet flew off!!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151789
MirKz, i was once into nos as i through it was cheap hp, if you look at the nos website they have different setup for different power lvls, i belived anything over 300hp they requirment you run forged internals.
i belived rev210, uses it in his car, and i think it was something like 100shot and he had good results also
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151915
croyden GTR did the same thing, only with his, when he reved and started a burnout, nos thought he was racing, so it put a shot in and had no where to go but up, and lets just saw, the bonnet only just stayed on.
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151980
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
