Hey all,
A mate of mine and i were discussing the other day, Nitrous oxide.
He was telling me that you can run a 50 shot of nitrous and it can be beneficial to ure engine (as it cools down the pistons a bit aswell as the rest), rather than destroy it.
Im pondering possibly doing this to my own car... but would like some opinions first. Has anyone here got a nitrous setup in their car? running stock internals etc? Does anyone know roughly how much it would cost to get installed?
All info/opinions appreciated :(
https://www.sau.com.au/forums/topic/60796-nitrous/
  • Replies 52
Hey, coulda told you this before but I think I forgot to. Seen a stock Ti R31 running 50 shots down the drags with complete stock internals. He claims to have done 54 passes at that point with it and it didn't miss a beat. Got some nice low 14s which is good considering there normally people trying to pull a high 15 in stock form!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151585
NOS is the "SHIT"! :)
I run an 80hp wet shot & the HIT is better than Viagra!
When set up propperly is is a safe & effective hp gain , tho getting it right can be an absolute BIATCH..... as those who were present at my first effort will testify.
As a result of this.....only a WET shot is worth doing (wet shot is where the correct ammount of fuel is injected with the nos).
I use Geogre at ADRENALINE for all Nos related stuff.... he's seen it all.
Go the Gas :burnout:
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151729
good to hear rep003,
so how much for somthing like this? do you still find it to be safe? I have always wanted to put it on but everyone always seems to say oh but this can go wrong and that can go wrong.
Plus not too mention the pic i saw recently were the whole engine blew up of the drag car when the lines caught fire! the whole bonnet flew off!!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151789
MirKz, i was once into nos as i through it was cheap hp, if you look at the nos website they have different setup for different power lvls, i belived anything over 300hp they requirment you run forged internals.
i belived rev210, uses it in his car, and i think it was something like 100shot and he had good results also
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151915
croyden GTR did the same thing, only with his, when he reved and started a burnout, nos thought he was racing, so it put a shot in and had no where to go but up, and lets just saw, the bonnet only just stayed on.
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151980
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
