hmmm...i dont know....
what i would do is look at random cars....and see what cars have indicators that might fit if they have spots in front bars.....
but try contacting nissan...they can usually get that crap from japan....ummmm and that other place that gets all the stock parts....
does anyone have the size of the gtr indicators because i think they are about 25mm (i think thats what your meant) radius...
is it www.justjap.com.au
edit: i couldnt find anything on justjap...what about fibrevision or somewhere like that im sure they could get some....
i can post a pic on the 29th of january. thats when the car gets back from the shop. I took this option cuz theres no way in hell i'm payin for genuine GTR ones, ($330) when im just as happy with cheaper ones ($4.95 each). Because the lamps are a bit bigger then the hole, then they stick out a lil bit, but i like it that way. I'll b sure to post pics.
Paul
Paul
Thanks Paul
yeah, ive got the GTR/400R ones in my 400R front bar.. at $160 a pop they arent cheap, lucky they came with my car..
trailer lights ive seen are very similar, basically just a yellow dome with a black shroud, and cost alot less :D
there are 2 types of trailer lamps.. the big square edged round ones that stick out heaps and look shizzle
or go to WA salvage and get the smaller more rounded ones... they fit really well and look quite OEM if done right
now alternatively... i think its the pajero or the daihatsu terios or something that uses a clear round indicator that you will find useful..
post a pic first though please..
So far, I went to few places around town looking for my indicators, only one place have been helpful and that is Xtreme Machines.....Credit to them . They know customer service.
All of the other shops, I won't name them , have been more than un-pro.........:rofl:
REsult = me not having my front bar put on, and now it looks I will be mounting my old bar back on to go to the cruise this Sunday. I am mad. Sick of people telling you they will call and they don't. sorry guys about this but it had to comeout..... :D
As far for the Extreme Machines, guys go in there and see what nice place it is and how organised it is. Very well done:)
White lenses, orange globes :D Would absolutely look the shizzle on your car cos it's white Al :D
I can't say I've seen them in trailer lights, but you might want to try Bunnings, as we stocked trailer lights there a few years (orange lenses but)
And you're right about some shops *cough* "oh, he only wants trailer lights, and he's not gonna spend megabucks at our shop, bugger it" is often the way.....
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
