G'day, how is everyone?
Just signed up. I own a black r33 gtst, number plate hicks, maybe you've seen it?
Just wanted to know when theres gonna be another cruise on?
seen you guys last friday night I think, looked like fun.
Also, anyone with an r33 gtst here pulling mid to low 13's.
i've got a 3'' turbo back exaust with dump pipe and hi flow catt,
custom front mount, trust air filter, s-afc and 14 pounds of boost. apparently I should be able to run 13.5ish but I can only get low 14's! only been down to motorplex twice. Think its my lauches,
any tips?
https://www.sau.com.au/forums/topic/6098-cruizing/
yeah I been motorplex twice, first time I had better better times than last wednesday. think it was the weather though.
how should ya launch em?
anyone else's r33 goes click, click, click, click, click, click, click,
from the air con vents when you start her up?
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92118
used to do on mine but I fixed it! but it's pain in the ass I tell ya! you have to take the whole dash a part...
unless you wnat to do that then just put up with it!
if you wanna still want fix it I can give you tips
cheers
Joe
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92153
Get some susupension bushes m8 appaerntly they help with traction off the line quite alot. U get less axle tramp and that kinda stuff so u can really throw it off the line. Do a search for 'pinapples' and u should find something. :D
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92243
Hicks, your black r33 looks incrediably like a r32 to me. Maybe I'm going blind. To run into the 13's you need a low 60 foot time, around 2.1-2.3, which means you need good off the mark traction. Whiteline make a diff craddle kit, its 4 poly-urethene bushes that adjust the rear craddle for maximum traction. Also a good set of tyres, dunlop f901's or sp9000's will do the trick and depending on your rim size. If you've got a nice set of 17x9" deep dish rims you can stretch some 255/35 or something over them, maybe 235/45. you want something with a fair amount of sidewall for flex when you launch. btw: I've only got a cat back exhaust, electronic boost controller set to 0.8bar, hks pod filter, heavy duty clutch and a set of 225/55 r16 dunlop sp9000's and I ran a 14.11 wednesday night just gone. Rev210 (dave) has got a turbo back exhaust, running around 8-10psi boost and he ran a 13.8!
Rob
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92273
nah, its deffinetly an r33. The only difference on mine is that I have had the rear nissan badge(boot lock) removed and filled over. Some tosser ripped it off!
My rims could be a problem, there 245's but theres not much side wall as the rim size is 19''. Looks good though!
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92277
i think i saw you on leach hwy near risely st a couple of times, the bootlock has been filled, and its still got grey primer right?
I have seen 2 different black R33s there, but i definately saw 'hicks' i could be wrong about the primer though.
Nice car all the same.
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92488
mine does that.. sometimes when i turn the car on it does so and the climate control wont turn on until its all clicked out.. im thinking its the air directional doozies or some crap *shrug*..
if it aint broke.. dont fix it.
Shaun
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92491
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
