Could someone shed some light for me in regards to aftermarket engine management systems that use a MAP sensor Vs an Air Flow meter!?
Drivability for both?
What power are you limited to if running air flow meters?
Any other peculiarities or problems etc?
I was recently running a Microtech MTX-12 sequential direct fire and that used a MAP sensor.. despite having the car tuned twice by different garages of good repute the drivability in terms of starting the car and low idle were not that good – other than that it was fine and made good power. I was told that this was due to manifold vaccum pressures and the map sensor needing to get it's sh*t together on start up.. hence it would stall a lot and need multiple starts.
It's driving me up the wall.. if anyone could help, that would be mostly appreciated. Thanks
https://www.sau.com.au/forums/topic/61104-map-sensor-vs-air-flow-meter/
Hi Conrad, I have seen 1,100+ ps on a pair of Q45 AFM's (90 mm), I don't believe there is a power limit. You simply use bigger AFM's, I have seen 100+ mm AFM's, a pair of those would be good for 1400+ ps.
An AFM measures the airflow going into the engine. A MAP sensors measures pressure and the ECU works out the airlfow using throttle position and rpm. So a MAP sensor driven ECU can never be as accurate at finely measuring ariflow as an AFM driven ECU. This is most noticeable at low rpms, cold start, cold run, stop start, traffic, air con on, power steer, electrical load etc etc. A MAP sensor driven ECU can be tuned to give as much max power, but it is so much harder to get the car to run "nice". Sometimes it is simply not possible, this is most noticeable in GTR's as they have multiple throttle bodies. It is almost impossible to get a decent/accurate/consistent pressure signal to feed the MAP sensor.
My recommendation for all road/combo cars is the Power FC, GTR's make good power wit them and run as "nice" as with the standard ECU. The car that makes 1100 ps with the AFM's runs a Power FC (BTW, it does 8's at ~165 mph).
Hope that helps:cheers:
Cheers thank you for that, I hate that feeling of hearing a thousand different versions of a story by people less in the know.. ok that cements it for me. appreciated.
My microtech died so I'm going to have to purchase wiring loom, 2 airflow meters + plugs, then get it installed and tuned.
To keep cost down as this aint going to be cheap.. do I have to fork out $300 each for Z32 AFM's or can I use the RB20/RB25 AFM's? Are there any blatant advantages?
I have been running a R33 Wolf 3D plug and play for the last 6 months.
It uses an internal MAP sensor or can be configured for an air flow sensor.
I chose the MAP.
Developing power on the dyno was easy and is repeatable and reliable.
As the SK says the MAPs do not meter small levels of RPM as well as the air flow sensor.
In fact I have had a ball over the last 5 months setting the tuning as best as possible at idle and with engine load such as air conditioning and lights etc.
It is good now but not as good as factory ECU.
I have cold starts and warm ups as good as factory ECU, but has taken many hours.
Cheers
Rob
I'm using a Haltech E11 on my RB30DET. It can use an AFM or a MAP sensor, the latter can be calibrated to suit any brand through the software. I'm running with the MAP and cold starts, idle control, light loads are all excellent. Not a plug-in like the wolf though.
Well I have seen 400kw with RB26 AFM's.. we then upgraded to RB20/25 AFM's.
You can push the stock AFM's past what they are recommended to do.
CONRAD,
I notice you are in Adelaide?
Who's been doing the work on the car?
Have you had Tim Possingham (Previous RPM Owner & Microtech Buff) have a look at it?
Shaun @ Boostworx also has had good experience with the microtech.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
