Does anyone else's RB20 idle funny?
Mine will sit at around 600rpm, and then "hunt" up and down between 600 and around 800rpm.
It's really annoying coz it feels like something's wrong.
This has happened since I got it, before any mods (ie. bov, bleed valve, fuel pump).
How can I fix this??
ALSO ...
now that I've fitted the bigger fuel pump, it seems like it's harder to start the car?
It takes longer for the car to start when you have the key turned?
What could this be?
https://www.sau.com.au/forums/topic/6125-shitty-idle-and-longer-start/
jimih.. all of the above are good points..
I'll add one more..
Also try reseting your ecu.
since you've got all these new mods, you should reset the ECU and then go for a thrash so that it learns things from scratch..
there is a thread on how to do this but here are quick instructions..
**disconnect battery.
**Step on brake pedal until all power is drained and the brake lights no longer come on.
**Plug battery back in.
**Start car, thrash it around for a few minutes around the streets.
**Done.
"Hunting" could be the early signs of the AAC valve starting to play up. Just needs a clean.
The "start" problem - I was reading last night that too-cold a plug can cause cold-start problems.
AAC = Auxilliary Air Control (don't people read posts around here? I've lost count of the number of times I've had to explain that). Its at the back of the plenum chamber. Disconnect the orange plug to see if the idle stabilises.
You need to run a lower heat range number. I run a heat range 6. I think you may need to go to a heat range 5. Go to www.ngk.com.au - it has a FAQ about plugs and there is a question specifically about the heat range.
Do you have some sort of computer ie. S-AFC?
Theres an option you can turn up and down, forgot what its called but its for atmospher bov's(stops the car kinda stalling when the boost is released) when this is on cold start is shit!
I turned it off on my car and haven't had any problems since.
But like others said, it could be your air flow metre.
I'll add one more..
**Done.
I read that on another site, didn't know if it was true or not. Didn't have the balls to try, thought it might **** up all my settings.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
