hey guys,
Due to a change in circumstance it looks like i've gotta pick myself up a wagon so im thinking a stagea would be a good bet.
Just from looking around it seems that all stagea's except the autech 260RS were factory auto's? Has anyone attempted a manual conversion yet?
For a manul conversion i'd take it you'd need to borrow most of the gear from a 33 GTR and go from there?
lastly from a seat of the pants driving experience do they feel any bigger than a GTST at all?
Cheers!
Luke
https://www.sau.com.au/forums/topic/61327-mentally-inept-stagea-question/
U can get manuals in normal Stageas Series 2 (1998 onwards) - just will pay a few thousand more than auto - and Ive found none yet in Oz, so might have to ask a yard to find u one or go through a broker like geoff risbey from prestigemotorsport to find one in japan for you. A Tiptronic series 2 is other option (no normal auto was ever done in series 2 stageas) and these are available now.
But yeah otherwise conversion, and some of the fellas here would know about that probably but not me sorry.
Adam
Cheers!
Luke
Hi Luke, there are a few guys on here that have done auo to manuals conversion, thye can give you the details. I would suggest that if you really want a manual that you buy one in the first place.
As for driving impressions on Stageas there is a thread on it, with quite a few guys input, I suggest you have a read.
As for a direct comparison to R33 GTST, well the Stagea is 4wd, same as a GTR. They are heavy, mine is 1660 kgs, so they don't feel as nimble as a GTST. Obviously they are a waggon, so the rear CofG is higher than a coupe or a 4 door. I have upgraded the stabiliser bars to compensate for that. Due to the weight and 4wd, in the wet they are awesome, it is simply all traction. Add some upgraded shocks (Bilsteins in my case) and a handfull of alignment products (adj camber & caster) and the handling is very good. Much better than most cars and streets ahead of any other waggon.
Obviously the engine benefits exactly the same from mods like any RB25DET. Since you have traction in all circumstances, they can take advantage of ALL of those increases in power.
Hope that answered your question.:P
  • 4 weeks later...
I am going through the research of this right now too actually..... Trying to weigh up if its worth importing the manual version or doing the conversion when it gets here..... After speaking to my broker It apears the autos can be bought at aution as low as 7 grand cheaper then the manual which is what I want to... now the questions I am going around trying to solve is it worth paying the extra or doing the conversion here, should I take the gear box out of a GTS-4 and I have an added problem of wanting the slightly later model with the NEO engine which comes with the tiptronic auto... so looks like there are some added difficulties.... but I am going to go talk with my mechanic today to find out whats the best plan....
If you really must have a manual, then I strongly suggest that you buy a manual. The money will come back to you when you sell it. A "real" manual will always be worth more than a converted auto. Plus I doubt whether the cost saving would be that much. The manual S2's are not commanding as much premium over the tiptronic autos as they used to.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
