Dominoes can either be really good or taste like cadboard - the trick is to dont be a lazy arse and pick it up yourself ..... get it delivered by the time it gets to you its awful!
I found that myself with "EAGLE BOYS" they make some shit pizza, the one @ great estern hwy.
  • Replies 310
momma?
Get my movin stick momma wants to go to the video library and get me sum stories
:bahaha: Simpsons quotes!
"Doctor said i wouldnt get nosebleeds anymore if i kept my finger out of it"
Yep i used to work for Pizza hut at one stage, ran my Skyline into the ground sure it was a c210 but it would have lasted longert than it did if i wasnt caining it about delivering pizzas every weeknight. Still u get free stuff on occasion, after a while u cant stand it though.
For teh ultimate pizza try Pizza king in bullcreek off parry av very good pizzas
Yeh i thin PH was pretty much teh same but it was as bit more. so u got like $2-3 a delivery plus $6 an hour or something. U can usually do around 4-5 an hour so its not all that bad in teh end but it doesnt cover repairs if it breaks.
i used to work for domino's as a drive u get $1.25 per delivery... that is meant to cover ALL running costs... fuel, vehicle maintenence etc etc
riiiiigggghhh! that wouldnt even cover a sil80 on boost. :D
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
