I thought I recognised that car in the avatar.. I seem to have spent some time under that bonnet, no where near as much as I did under the 180 but....
You should see it now with my Work VS-MX rims on the rear, the dish perfectly suits it..
  • Replies 310
for lunch, or after work pizza?
Both :) or either or. i have a day off that day. so any time is good for me. although you might want to give me a call before hand. I could be at cottesloe working on my tan.
hmm anchovies eh? an explosion of dry salty fish...yuk
pepperoni, black olives, pineapple and black pepper  mmmmmm
Pizza King stack on the toppings too
i eat anchovies out the tin. :wassup:
Pizza nights cool - best be on a weeknight as SAUWA weekends are pretty jam packed for the next month.
this friday night?
not good for me .... saturday is driver training ..... got a bit of running around to do last minute things to car and pauls folks come home this week so he'll probably be catching up with them.
i couldnt resist... i just had to go to NYC and get some.. i had the bronx pizza.. with chicken chunks, sring onions, bacon, motzerella cheese and tomato base... to die for!!! :D
now all i taste is onions.. ;) soon change that!
-pie
wat the ****........? lol
anywhos to add to this little pizza shenanigans...... Il Pedrinos or some shit like that in northbridge accross the road from the brass monkey...... best pizza in perth for sure..... how do i know because he was crowned worlds best pizza maker a few years back and he has cooked and served pizza to the pope............ it is lovely
adrian :D
my bro used ta work at a lil place on the water in south yunderup (its near mandurah) and his boss used ta do me the nicest wood fired pizzas baked capsicum satay chicken pieces pineapple lil onion bakon fresh mushrooms with heaps of mozarella was so good an got for free cause i used to run her home when they closed
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
