  • Replies 111
Actually since we have nearly hit 10 I will start organising the shipment this week. No money is necessary at this stage since I only need to give him 30%. I will let everyone know when I need the $100 deposit. At this stage Im estimating about the end of Jan.
Actually I'm going to order another 10 coolers out of my own pocket for others if they are interested. So thats a total of 20 all up. Unfortunately it does not change the price - need to purcahse 50+. If I bought 100+ then I could get a hybrid logo :cheers: ...
can't you get 100 out of your own pocket??? :cheers:
jokes dude. Also a quick question, about warranty or any problems, how long is it and what do we do with it (hopefully no dramas but thought i'd find out)
thanx mate
I'm currently in the process of finding out about warranty from the manufacturer. But from me I always check out the good before I post them off. Make sure they are in excellent nick. So from my end the if the parts is not what I described or there is a problem when you receive it I'm happy to exchange it.
Will get back to you about manufacture warranty.
sweet dude. your on.. No deposit just yet. next week I will talk to the manufacture let him know the deal. I will post up next week more accurate dates of arrival in australia. At the moment I beleive it will arrive between the middle to end of feb.
Status
Well, we have hit 10 cooler :D Today I have contacted the manufactures to ask them to begin production on our coolers. So once they finish making them they should be on the next boat to brisbane. Once they get on the boat I will need atleast the deposits from everyone so I can pay the other %70. So here is my ETA list
production finish end of month.
Ship to Brisbane (next available ship) 1st feb : Will need at least deposits at this point up to when the ship arrives. So deposit need to be paid between 1st to 15th feb.
At brisbane 15th - 20th Feb
My house hopefully in a couple of days: 23 Feb
Your house 26-28th Feb..
this is just a guess at the moment. When the ship sails I will have a more accurate ETA.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
