Awsome wheels..
in the process of getting me self some...
I need help.... sorry to steel your thread Terminal.. but if someone can gimme an oppion on these wheels... please speeeek.
Thanx
Sorry for the doggy pics, and bad quality.
cheers
https://www.sau.com.au/forums/topic/61660-shiney-new-ones/#findComment-1164591
I picked up some nice new 18" wheels on the weekend, look out for me shining near you soon :rofl:
Ah,THAT'S better! I agree with Veilside-time to "go low". Inline,you say? Another good choice! And the photo location? It seems so...familiar,somehow. It has a magnetising pull to it,especially when I'm driving my Nissan GTR...LOL!! Top place to photograph any Nissan!!
https://www.sau.com.au/forums/topic/61660-shiney-new-ones/#findComment-1165211
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
