  • Replies 53
Thanks guys, at the moment the cars are Nismogirl, Melv, JLNewton, twoquik and us. Ill PM everyone in the next few days and get organised, but the date is the 23rd of April, so if anyone sees 5 white Skylines on that day, give us a toot.
Cheers all, the response was wicked.
Ads
  • 1 month later...
Hey Erin, yeah the go at the moment is its on the 23rd April, we will be in two places on the Nthside, so ill have to split everyone up, but i have maps and everything ill email u guys, and its 2:30pm wedding and stuff, so we'll need you from about midday until about 5:45pm. Lots of cool photos also, and ill make sur e they get posted.
Would love to catch up with all involved beforehand, as the only one ive met is Ben - Twoquik
Ill pm u soon.
Thanks again guys
So we are washing our cars and having them up to photo quality? :D
I just remember in one of our conversations you were tossing around the idea of detailing the cars. Not complaining, just asking so I know that that saturday I have to spend it washing my car :D
Yes sorry, had to bail because of the ugly carpark incident. The car was supposed to go in on the 12/4 for the repair but they rang today to put it back to the 10/05! Wasn't happy about it, and let them know that I required the car for a wedding on the 23rd and the best they would do was to book it in on the 20th. I don't want it rushed and I had a few "extra" things planned so I have had to bail...... women, 4wd and carparks....*sigh*.
The silver sedan is still available if need be though ;)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
