I hope someone out there can help me. I've got a '93 R33 GTS25 which need new front pads. I'm looking at EBC pads and can't find the actual size I need. EBC have two sizes listed; DP1082 and 1046 but without pulling my old ones out and physically measuring them they can't tell me what I need. My car is not the 'S type' and is still bog standard brake wise. If anyone has replaced their front pads in a '93 and can remember the product code and brand I might be able to match them up. Thanks.
https://www.sau.com.au/forums/topic/62042-front-brake-pads-gts25/
As far as I'm aware all the R33 non turbos have the same brakes, but I'm not 100% sure though.
I have a R33 GTS25 non type s and my brakes are 155mm long from tip to tip and have a width of 50mm.
So I hope thats of some help.
sorry for offtopic: but what exactly is the S type?
Repco or Autobarn wud usually have a book on the fitment wudnt they?
Type S, has a few standard extras, LSD, an extra few kw at the fly wheel, a different rear muffler, and a rear sway bar, well my friends one has anyway, and maybe a couple of extra things I have over looked.
Thanks everyone. The difference between the two pads I've been quoted on is minimal, both sets are 155 mm long and 17 mm, the width varies. One set is 53 mm wide the other is 49 mm. I know its only a small variation and the pads themselves are the same profile other than the width, just needed to know what difference it would make.
I guess the thicker ones wud clamp reasonably earlier than the thinner ones.
In the end they'd wear down anyway - so I'd say if the thicker ones fit then go for them, you'd
get more life out of them as well i am assuming.
skyla: thnx, I guess I "might" have a type S - stock exhaust has a little flap thing which I am curious about.
Yeah it sounds like it, my mates one also has hicas, and red badges on the front guard insted of blue like mine
That little flap is meant to be attached to a cable to allow u to open up the exhaust fulli. Its meant to open up at high revs and then close againt at lower revs for a more quieter note. Im yet to find a car that actualli has that cable but me and my dad were thinkin of somehow creatin a mechanism that opens up that second exhaust route at high revs to give a much better sound. In the end we couldnt be bothered so i just slapped a magna flow on instead.
Got the flap, the cable and the actuator on mine. Actuator is located inside the LH rear gaurd, below/in front of where the jack lives. Not sure what RPM level it activates at - I think I read > 4000 rpm somewhere?
yeah, i have it on mine also - when i chnaged to a 2.5" system i just left the cable in place where it once was and zip tied it outta the way - lol
and i don't know if my HICAS is locked - i am yet to see the light conme one (except when starting car of course) i assume it's locked - how cna i tell?
And about the LSD - when i do a burnout i get both wheels smoking :rant: but whats an official way to determine if your has it?
yup mine has the cable to open the flap too - I have yet to see it open though (cos I'm always
driving when it opens up I guess :rant:)
gatty: You can tell that your hicas is locked or not by doing a diagnostic (do a search), you can actually see the rear wheels move when your stationary.
Or when you drive, particularly around a roundabout, you can feel the rear end of the
car running sideways, it feels sort of drifty but obviously not on such an angle.
HICAS LOCK BAR
HICAS LOCK ON THE CAR
OR you cud just check under the car. :rant:
Dont quote me on any of this :) but from what I gather...
An LSD (limited slip diff) will let both wheels spin at different speeds, but it will just limit the amount of difference between them. So basically when you go around a corner, the
inside wheel will spin slower as it has less distance to travel.
I dont think a burnout is the correct way to determine that both wheels are spinning at
the same speeds. But if your wheels are spinning at the same speeds around a corner
(its most probably a locked diff) the inside wheel will chirp.
This is good for dragging, drifting and other straight line stuff ( I am not sure what is
appropiate for track work) But for street use the stcok LSD shud be fine.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
