Those plastic speaker holder thingies only hold 5 or 5 1/4" speakers.
I pulled mine out (the plastic things) and threw them in the bin and put in a set of 6's.
You need to make or buy a pair of wooden spacers though.
I got mine from JB Hi Fi for about 9 bucks.
This will make the speakers sit in the right spot (so your windows don't hit them) and make it sound heaps better.
this is incorrect!
how come i was able to put my 6 inch in the front in these same plastic speaker holders? the holes lined up and it fitted flucs no problems!
my windows dont have any problems either????
i dont know what kind of spearkers you have but!#$#??
Everyone has a different opionion to what size the speakers are. The rear shelf speakers on a series 1 R33 are definately 6.5 inch (I actually installed them myself). I havent got round to installing the fronts yet but I would assume they're the same size (judging by the size of the hole). It'll take about 20 minutes to take the door panel off, measure the stockie speaker, put the panel back on, and go down to the nearest car audio place and get the size that fits.
you are correct with this
and you are also correct by saying the back are the same as the front!
i installed mine back front myself thats how i know..however i have 6-9's in the back,
So they're 6.5 in the front doors??
Before you said this:
:confused: :confused:
shit now ive confused myself :)
Geez, didn't take much!! :cool:
I dont know, but I reckon the fronts would be 6.5s.
I put 6s in the rear but they needed spacers. This was a ridicuolously annoying task! Wood is better for this because its stronger than plastic. The speakers wont transfer as much energy through the wood, which means they are more likely to convert the power delivered into actual sound rather than movement and rattles. Basically the stronger the mount/enclousure, the better the sound.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
