Just fitted a K&N pod filter to my R33 turbo Skyline (replacing high performance HKS cold airbox) and have noted significant induction noise increase. However it seems very loud (drowns out 3.5" exhaust) and is quite invasive in the cabin. Is this normal? Am wondering if all pods are the same. Pod is un boxed (ie no covers in the engine bay) but even test cover made little difference.
* Also have noticed appreciable turbo lag aroung 3,000rpm. Esp in fifth gear (under load). Would fitting pod change tuning set up?
have no other car for comparison so thought I'd let it loose on the forum.
https://www.sau.com.au/forums/topic/62284-noisy-pod-is-this-a-silly-question/
it migh change the setup as the car is getting more air now..
and the noice is normal - but yes, some pods allow more air through then others - the K&N is a great choice for airflow whilst still having max filtration :)
it's normal and the sound is great :cheers:
Hey,
Had HKS "shrooms" fitted in Japan, though they got stolen on the boat ( beware of ship captains, 84 Colt sporting green pods)
Now I have the rigid K&N filters which make a heaap of intake noise. But then there are two.. so Im not sure if there would be more noise ( more surface area "sieving" the air) or less ( air speed / ferocity through each filter would be half, compared to running a single on a RB25) At any stage, I can almost tell what angle the boost dial is, by the intake noise.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
