  • Replies 66
Sorry roy... forgot to mention...
You set the scramble to a higher setting for a set amount of time. You can also make it go to a lower setting if you wish. The unit also had a fail setting. If the boost goes over a limit setting then it will go to a lower boost setting for a set amount of time.
EG.
I run 10psi
I have boost fail set to 11psi (this will flash and beep if 11 is reached)
Then it will run 7psi for the next minute.
This has only happened once when the ID-III read hose got crimped by a zip tie. This caused it to over boost and react slowly. All of a sudden i had 12+psi and i was rocketting down the road then there was a beep beep beep and the boost dropped off to stock and i scratched my head. Pulled over and looked at the boost graph and it all made sence.
  • 8 months later...
Can one of the SBC children do me a favour and set their scramble duration to 0 and go for a drive....i need to know if it will use the scramble setting whilst you are holding the button down. Dont want it for a preset duration, want it to activate while i am pressing a button
Dont want to buy the wrong EBC
  • 2 months later...
Mate sorry i totally forgot about this thread until i dug it up for a guy the other day...
I tryed (like 8 months ago) and nothing happened. You set it to 0 and nothing happens when hit scramble...
So there is the answer you have waited almost a year for... LOL
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
