hahaha as i said my supplier is the owner of the factory and guys...ppl are buying from Shanghai the company is called Oklead Trading Co Ltd ....hahaha oh well my supplier is very happy as i sold 15 coolers from this form so he told me that if there is anyone else want to buy then he can do $285 inc Shipping for 600*300*76 bar and plate cooler..i think everyone knows what the coolers look like to i will not put any pic here...
also with the 450*300*76 it will be $285 inc shipping
600*300*105 will be $380 inc shiping
all the coolers are come with one 2.5" to 2.75" for the throttle body with HKS hose clamp *2
so guys that's very very good bargain......
pm me if anyone interest.....
i have the 600*300*105 on my GTR 34 ...it's awesome...as i am running twin t51r turbo on the car....so don't worry about the quality and also these cooler are inc life time warranty....
https://www.sau.com.au/forums/topic/62595-intercooler-280-delivered/
agreed guys - but maybe we should leave the man to the sale before the mod team gets pissed at us......lol
//Please post pics - i would like to see the quality of the cooler, also why is the smaller cooler the same price
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
