81 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ha ha- well, after checking out the "fragrance fairies" (i kid you not) on offer at SuperCheap the other day, I'm sold!
My vote - I'd be happy to pay for a new car with leather interior smell : )
Not to mention helping a fellow SAU-er get a business going!
Those clip things here in perth are $4.50 from Kmart! they are by far the best. You get 4 per pack and I only use 2 on my vents at a time on the middle ones lasts about 2 months then use the other 2 for another two months! i buy them in black so you can barely even notice them..... so my car smell nice without some peace lovin hippy tree thingy floating around in plastic bashing the crap out of the plastic and giving me headaches....
clips are my favourite!
those ambi pure are $6 from Kmart.... Perth.... the home of cheap smelly stuff :-)
I love my Shell Lavender car deodoriser... its about 5 bucks, but goddamn it gets rid of any smell possible, comes in a vaporiser bottle (not one of those ugly things you hang on your vents which eventually breaks it), and smells awesome.
You got no option for "I like what I have and will take something that shoots fireworks and butterflies when I spray it to make me change"
I would never use an air freshener because of allergies (eye's water, cant see the road etc) but i reckon there'd be a huge market for smell neutralisers because even when i'm in a position to import a car from japan, one thing that's really putting me off the idea is getting stuck with an interior that smells of smoke, which i cannot stand...........and considering that the Japanese are some of the heaviest smokers in the world, i cant imagine the chances are that slim.
there must be a market for a oder killer product in the jap import market..........i'd definatly pay for a top shelf one that did the job if i needed it.
i used Febreeze every now and then in my r33 gtst (sold) to keep it fresh and an excellent odour/bacteria killer. Don't like air fresheners or such as it would leave a lingering smell. Now I got a Magna with leather interiors,but would still used it on the carpets and other fabrics parts.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
