ok this is the problem
the passenger door wont lock. i use the central locking the latch moves on the inside of the door so it looks like it has locked but you can still open the door. tried locking the inside by hand and closing door but you can till open it from outside as if it wasnt locked.
also tried closing the door and locking it from the outside with the key, it feel like it has turned far enough to lock the doot but it wont lock.
removed the trim from the door and played with the lock mecahanism, everything seems to be moving like it should but it just wont lock
any ideas what is casuing this and how i should go about fixing it?
thinking of taking the mechanisim out of the door to check in out and try and clean it but they way the rods are connected to it will make this a problem.
btw this is on a 32 gts-t
any advice would be much appreciated
https://www.sau.com.au/forums/topic/63030-passenger-door-lock/
took the whole mechanisim out today and it all seem to be in order with no obvious faults. its a sealed unit so i cannot really open it up with any hope of puting it back together in working order. think my best option is try and source a repalcement from somewhere
I had a similar problem with the passenger door lock on my R32 GTR. The mechanism looked normal, but close inspection showed that it had 'split apart' a few mm near where the lock rods attached. This had allowed some of the internal mechanism to come adrift and of course it didn't work properly.
New mechanisms are still available through Nissan, but have to be ordered from Japan (2 week wait) and are $200+. I ended up sourcing a good secondhand one from an SAU member.
LINXUS40 i have exactly the same problem, it closes all but 2mm from locking on my 32 gts-t...... i took mine apart also and there is nothing obvious, i changed nothing then put it back together and it worked for about 24hrs before it shit itslef again.......
dont know what to do bout it???
Yep, same here. I've had it for about a year. The solenoid closes down, but not enough to completely lock the door - normal wear and tear I was told. The only solution I've been told is to replace the unit and, you don't have to use the OEM item. As long as the solenoid works on the same electrical configuration she'll be sweet.
My Passenger lock has been doing strange things lately....When i turn off the engine, Both doors should unlock right?.......LAtely its been very fussy somes times it does, but most times it doesn't...otherwise it works 100% OK, the button in the arm rest works, as well as the alarm/mobiliser remote......it seems very strange?? :confused:
  • 5 years later...
Hope no one minds me dragging up an old thread...
My R32GTR drivers door started exhibiting the same symptoms as your passenger door linxus40, so I pulled off the door trim for a look. Initially there was no obvious cause, so I removed the latch assembly and discovered that one of the black plastic clips that hold the white plastic cover in place was broken and the cover had partially separated from the body of the latch. On closer inspection this clip appeared to be a pivot point for part of the mechanism, and this was mis-aligned which was the root cause of the problem.
Now my question is what is availability like and how much should I be paying for a replacement latch, found one (used) on ebay (in Australia) for $39 plus postage, which seems pretty reasonable, but as we all know used parts are a lucky dip, might last 10 minutes or 10 years.
Also I am wondering if this is a common problem, anyone else had this?
Edited by DAT510
I have the same problem. If anyone finds a solution or needs some teamwork just say so. Can't get to the lock properly, called up automotive locksmith but never got to the point where I got it inspected. They said it could possibly be the central locking system.
Edited by TyresBro
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
