alright i have done a serch and keep finding post about calipers and disc jjust want to know what brake pads are you using and what do u se them for eg track drag racing drifting and how well do they hold up and the price you paid for them i have a toyota cressida with r33 calipers going on the front soon well brake pads is what is holding me back now the car will eventual be used for track so yeah any ideas what i should use
https://www.sau.com.au/forums/topic/63125-brake-pads/
Duncan, you don't get fade with ultimates on the track?
nope....the stock gtst brakes are excellent :D ultimates, good fluid, dba4000 series rotors.
I did run semi slicks a fair bit which definately reduces the stress on the brakes, but even when on road tyres they were OK
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1190184
i rang up race brakes today in melb they are going to supply me some brakes that are simi track street on the front and more street on the rear thanks for your help guys
Most likely RB74 (front) and Comp2 (rear).
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1190187
NJR 34GTT]
[/b]Duncan, you don't get fade with ultimates on the track?
I use the same as Duncan with no dramas at all. My engine oil gets hot way before my brakes have a chance to fade.
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1190748
I just used a set of NIZMOs on the front of my R33GTST for the Queensland raceway track day, Braking performance about same as Bendex Ultimates - but they last heaps longer and not as much dust. I've never had fade with either pad. I had a set of Ultimates as spares but I did not use them.
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1190800
Bendix ultimates for 3 to 5 lap sprints. For 20 minutes races you need Hawk carbotics, I prefer the Blue (9012) compound for cars that go around corners as well as they go in a straight line. For cars that don't go around corners very well, in comparison to their straight line speed, then you may want to use HT15's. That compound has a higher intial bite and tolerates the high temperatures caused by the necessarily heavy braking.
The alternative is Performance Friction Carbon Metallic, in the 01 compound.
Hope that helps:cheers:
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1191278
What are they like on the rotors SK?
Ultimates are very gentle, Blues are not too bad, PFCM leave a residue that needs to be removed regularly. But they do stop, the co efficient of friction is very high and it stays that way over high temperatures.:D
https://www.sau.com.au/forums/topic/63125-brake-pads/#findComment-1191645
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
