Laurel Hill Camp, CONFIRMED 27, 28 and 29th May 2005
I've stayed there a few times. And fishing can be done for sure. If you guys wanna come and have a look pm trident and me, we can meet you somewhere near there.
  • 3 weeks later...
Hi Gents,
Yeah, I asked around yesterday, and can DEFINATLEY bring 4 people, 2 skylines... thats without ARM85 who'll have someone with him plus a car. There is another 4 or 5 lines new in town I'll chase this weekend. If one of them goes thats already 7-8 people. 4 cars,
Albury will have a few people there at least, and it sounds like Canberra has at least 3 cars which are solid.
I might just bump the ads threads again, and see what happens.
Thats a few at least - enough to go lcose to getting our numbers..... If everyone brings a buddy/girlfriend/wife/ kids/lover/boyfreind/interested person/skyline enthu or whatever if I missed something, numbers of people would build up pretty quickly. I have to say tally ho gents. We're off to the hills.
Maybe get onto NSW and VIC executive to get things going there way. 6 weeks is good notice. Maybe we should just start to plug. I think it'll get going.
Maybe WE should put our deposits in..... he he he
Only thing is the camp needs some money soon (end of month).
  • 4 weeks later...
Hey all
Thanks for your interest, however due to a lack of definate yes'ers, I had to can this event.
Soirry for all who had plans, but have a look at the events thread for ACT and NSW for ....
OSCAR'S HUGE HP DYNO DAY!!!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
