Ok, I've never bought a house in Japan before (and I don't intend to) but seeing as you asked, heres what I came up with:
4LDK 2 story house (thats 4 bedrooms, living, dining, kitchen) for US$373,364.
I got it from here Century 21, and I strongly suggest that you call them (they have english speaking staff) and talk more about it because I honestly have no idea.
I'm from Australia and buying big houses as investment properties is part of our culture, so buying a house in Japan (small, way too expensive for what you get, rapid depreciation etc) is not very wise for the foreigner... unless you're going to immigrate here?
houses are expensinve here... we were comparing my house at home and my girlfriends house here in Saitama/Tokyo and they are worth about the same... (800,000AUD) the only problem is the land is about 1/6 the size and the house is about 1/3 the size. Kiss a backyard, central heating walk in wardrobes etc good bye.
Thank you Rezz and yes I plan on immigrated there. That is a hella of lot cheaper than it is here(California, Usa) Depending on where the house is I meant rent, if I find a good deal if not just buy. Which I rather do, but it all depends. I will have to look on century 21 then I will probally call them. Thanks guys
Try this site, it's only available in Japanese, but you should be able to guess your way through the site by way of links. This link is for the full 23 wards of Tokyo Met. I live about 15 mins from Tokyo, the prices here range from about 400K to about 1.2M USD. Our place is 4 BR, study, on 250 m3 land with carport and was 600K if thats any indication of costs. I would not recommend buying unless you are planning on staying at least 10 years, any less and its a waste of money. Either way, you will lose money, but if you are here for 10 years at least you would get back what the house owed you (kind of)
http://www.jj-navi.com/shuto/FJ021S90030.d...98&SCF=1&CNT=50
Good Luck.
LegnumVR4
lol @ carport/garage... why can't we just have one name for it? I was taught British English but teach 'American style' English, native English speakers not knowing what the other is saying drives me nuts.
Mostly for rent but this might help. Buying a house in Japan is complicated business for a foreigner. Best of luck to you!
http://www.housingjapan.com/
http://www.kencorp.com/property/index.html
http://arkios.co.jp/propertiesbyrent.html
Garage versus carport
'The obvious difference between a carport and a garage is that a garage can be completely closed in while a carport has a roof and pole supports.'
Taken from this 'Australian' website... http://www.homesite.com.au/renovate/garage...s_groundwork_1/
:D
VR4
:cheers:
VR4
lol somebodies bored! :D
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
