Yeah.... My problem is im an auto elec so fitting is not a problem....
However when ever i call round to find who reckons one is better i get different answers. One guys said "You wont be able to fit it yourself, ill charge ya $200 for installation" I laughed. Its a plug and play you idiot....
I just need to see first hand on a car with similar mods what ECU setup they are using. I mean i have done about 6 PFC on customers cars before, but never tuned then. Just wired and supplied the units. Wolf and I dont like each other. I did a Wolf 3D on a twin cam Gemini once which was the biggest nightmare. Just would not work properly, could not tune it. Ran like a bag, just nightmare. So i have not touched another Wolf from this experience over 4 yeas ago.
I assume the Wolf3D you used was not the version 4, specifically because the version 4 plugins havent existed for 4 years :P
PFC and Wolf3Dv4 Plugin are basically identical for fitting - literally plug and play, and driveable on the base maps. But the PFC controls idle up when headlights and/or AC is turned on, and Wolf doesnt. There are several other fairly minor points that Wolf doesnt do that PFC does, but its those minor things that make the difference between a perfectly streetable car and a bitch. The Wolf plugin also supports MAP sensor though, as well as a few outputs for various things, the person to talk to about these would be 'summoner'... His RB26 Cefiro runs Wolf v4 and he loves them. But then again he's strange in so many other ways too.
Having now owned a car with a replacement ECU (Haltech E6K in the VL), I'll never be doing that again :D Those "minor things" I was talking about in the last paragraph really make such a huge difference overall.
  • Replies 46
yeah well i seen a dvd of it on the dyno getting tuned by sub zero - with gas had no traction with boot lid off - about 5 guys in boot and 2 guys stadning on the side of the car - it was 779rwhp but still spinning - insane
silly things like that make me weak at the knees :rofl:
ps: i want some footage of SLO32 on the dyno... SLO31 has a baby version of SLO32 :rofl:
too bad SLO33 isnt following suit!
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
