selling my hks gt2835 turbo. turbo is in excellent condition, no excessive shaft play or leaks ect. Comes with HKS cast exhaust manifold and 40mm TRUST external wastegate and screamer pipe. I was making 260rwk on 17 psi on my rb25. Selling for $2700 ono
pm for details
turbo still on car but will be removed asoon as sold
  • Replies 54
yes the manifold bolts straight on to the rb25. will require oil and coolant lines plus the dump pipe which im not selling due to needing
Yup HKS use Garrett cores and modify these then use their own compressor and exhaust wheels/shafts to suit...
on the outlet pipe from the compressor housing (connecting to cooler piping) there will be a Black plate stamped on it saying HKS GT2535 with a serial number if its genuine
- adz
- adz
on the first pic you can see the hks gt plate near the snout. It is a genuin hks gt2835 and has all tags on it.
yeah its an awesome turbo. full boost in 4th gear just over 3500rpm. im selling due to doing an rb30det upgrade and want one abit larger. This turbo uses the .73 rear housing and could make around 270 - 280 rwk with more boost
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
