I have got a R33 GTS with RB20E engine in it. I think the head gasket is leaking as there is oil leaking around the top cover!!!
Anyways..I thought rather than doing any work fixing this engine..I wanted to change it for the RB20DE (get a bit more power with a little loss in fuel economy? (its my daily run around so can't afford the petrol bill of a turbo)
Does anyone know if this engine can be changed in to the my R33 chassis? Will it be a straight swap or do I need to change other things like the gearbox and clutch?
Thanks
Going on holiday for a week soon so thought I'd send my car to the garage while I'm away! :(
https://www.sau.com.au/forums/topic/64183-changing-from-rb20e-to-rb20de/
Might be right about the rocker cover...I'm might be giving parts the wrong name! cheers. My oil pressure fluctuates while driving at steady speeds, could this be due to the loose rocker cover?
And yeah had a chat with my local mechanic...said the wiring probably needs changing and other bits and bobs which would add up to a big labour bill....might aswell get a proper engine put in!
So I think I will try the sealant for now!
Was hoping that it was just a case of unbolting the rb20e and dropping in the rb20de...nevermind. Just happened to come across a crashed RB20de.
Whats the fuel eco of RB25DET? I do 60miles (100km) everyday so i presume my fuel bill will be massive!
Thanks for sharing :thumbsup:
Rocker cover dusnt have any affect on oil pressures... (what exactly are u talking about??)
oil pressue will fluctuate when u apply the throttle accordingly (there is a thread with the
correct oil pressures when idle, and throttle, etc - try a search)
Fuel economy varies as alot of force induced cars have either been boosted or have some form of extensive modification - I am not sure about the stock standard economy you
will have to try a search, or post in the forced induction section.
As for an RB25DE (non turbo) I have managed a bit over 1/4 tank for about 200km
that is about 20~25L driving pretty hard.
theres a big difference in price between a rb25de and a rb25det. If u wanna keep it non turbo then i recomend a rb25de. makes alot more torque. A decent mechanic should be able to do the labour costs for 500-600 i rekon, as this is wat i was quoted to do a rb25NEO in my r33. Bear is mind that other bits might need changin as well so these are additional costs.
Is the RB25DE and the RB25DE NEO-Spec a straight swap conversion? I am aware that
the Neo has a few extras such as stronger internals? and bits here and there...
but things such as wiring? ecu? compression? could you just swap the engine and retain
the old stuff.
Think the RB20E will be able to take a shot of N2O just for fun? or will the internals be a bit weak on this engine?
The oil pressure gauge shows a lower than usual reading every so often at idle and in motion. I know it should change on applying the throttle but the reading doesn't seem to show this.
There doesn't seem to be any performance problems, just the leaking engine.
Whatever, I'll leave that to the mechanic.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
