when im loading up the car in 2nd/3rd/4th sometimes the exhaust temp light flashes. so i stop accelerating, now when i press up on my hand controller to bring up "highest" rating during acceleration it shows little knock, like 20-30.
should i ignore the exhaust temp light?
there are 3 things that will cause the exhaust temp light to come on for R32
its covered in the PFC FAQ, its the same as the engine check light
the FAQ is down as the vhost is broken but when it comes back up, youll find what you need in there
Cheers for the FAQ mate.
Have an issue with my PFC on my r32gtr.
Its working fine in every aspect but it has ceased to display my speed. Any idea as to what could be causing this or where it gets it signal from. Have hooked up a mates hand controller but still no speed reading. Bloody frustrating as rely on it at trackdays for info as am usually concentrating too hard to read the speedo. LOL
Be great if someone could solve this for me.
Cheers
does the std cluster speed guage work?
i believe the FC signal and the guage cluster one come from the same source
or it coudl be a case the ECU gets the signal from the cluster
trace the wire to find it ?
R32 GTR gets the speed signal from the instrument cluster for sure. I broke the speedo cable and lost the speed signal. If I spin the input at the back if the speedo I can see the speed on the hand controller.
Edited by Waza_GTR
Yes i have changed the instrument cluster (how obvious, this was lost in all the other stuff i was doing ) That and i didnt think the signal came from the cluster but from a tach signal else where. Had to rewire the cluster too as was from a later model.
Many thanks Guys for putting me on the right path.
Cheers :)
You may have the speed sensor wires reversed on the new cluster. The newer model gtr cluster in my 89 bunky needed this (as well as all the rest moved that you already know about). The speed sensor is shown as a set of switch contacts on the wiring diagrams, but if you look on the back of the cluster on the circuit board you will see that there is a marking for a zener diode, that gives the hint, polarity conscious.
Hope that helps.. I can even show you which pins you need to swap if you can't find it as I kept my notes.
James.
the FAQ is back online;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
i am no longer accepting pm's any more - i've had enough
if you want to know something about the powerfc search in the faq
if its not in there i dont know the answer
ive had too many pm's over the past few years
people dont put in the effort to search
thanks
Hi Paul,
i hope the above doesn't relate to the below as it's not a commonly talked about topic so not sure a search will reveal much? Pm me Paul if your have time to help, i realise i wont be able to reply to your pm
can you help me figure out which wire i need to connect for the TPS on my GTS4 with GTSt pfc
thanks Steve
two questions paul
1. Can a normal Power FC be used with a map sensor and some how converted?
2. i know this is not realy a power FC question but Power FC datalogist software do you have a list of all the features it has and can do? as i tried to contact the distributor as i would like to know what it can and cant do before buying it but all they told me was to buy it due to it being the best.
Hi Paul,
thanks Steve
search on google or my site for pin out diagrams for the rb20 ecu
then you just need to find the TPS signal wire
should take you all of 30 seconds searching in google or the forums for
rb20 pin out diagram
the wire is labelled "TPS" as you would expect
two questions paul
1. no it cant, the normal powerfc expects an afm, the djetro version expects a map sensor, you cant mix and match
2. this is covered in the powerfc faq to death, there is a massive topic on datalogit, i suggest looking in there - the url is on page 1 of this thread or in my signature
sorry about that
but thanks for the help
no need to be sorry its just im kinda over a trillion pms a week about the same stuff over and over
especially given its covered to death and detail in the pfc faq already -thats the point of it
your questions were fine as they arent common and arent listed in the faq
Hi Paul,
I have read carefully through the faq and i have a issue that was covered for the power fc not the power fc d-jetro.
Basically i have 3 bar map sensors on the gt-r and when i want to run more than 20pounds of boost they go off the scale on the hand controller as we are tuning...
So if we use the software on a laptop etc will we be able to fix this issue?
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
