Ok I blew a radiator hose yesterday, no biggy all fixed but my oil temp/pressure is going spaz.
Here's the water temp, oil temp, and oil pressure after my 30 min drive to work that is light suburban, light city, and open motorway driving. No thrashing at all and this is after I let the car warm down for a few minutes coasting down to the bottom level of my carpark...
https://www.sau.com.au/forums/topic/64237-my-car-is-sick/
Water temp looks pretty normal biatch, Maybe just over the half line..
When this happened to my car, I cleaned the radiator, dropped the heater lines and flushed the hole lot. It was scary the amount of poo coming out...
As for the oil temp, no idea.
https://www.sau.com.au/forums/topic/64237-my-car-is-sick/#findComment-1205296
