1987 R31 GX manual sedan in Perth.
Ok, where do I begin...... It has -
Autowatch alarm with all the internal movement sensors, shock sensors etc, got receipt
Autowatch remote central locking to the front 2 doors, got receipt
GTS-X 15inch alloys with 4 good tyres - about 90% tread on the back and 50% on the front
Lowered King springs all round
Monroe Sensor Trak shockies all round
Extractors and sports muffler - not too loud, has a nice note, none of that 6 cylinder drone, been a lot of comments on how nice it sounds
Is a 5 speed manual, gearbox is sweet as, no horrible noises and changes gears like a dream, clutch is also perfect!
Diff has a bit of a whine which is typical for a 31 but there is no play between gears and no clunking or anything like that
Motor doesn't miss a beat, only problem is that there is a rear main seal leak, another common 31 problem. Its not too
bad, just gotta fill it up every now and then and doesn't drop any on the floor overnight or anything so really
is a slow leak
Has a pod filter
Is an 87 model but have put the S3 rear end on it so its got the round tail lights etc now
Has got SKY087 plates but I am in 2 minds whether to keep them as my little bro's Skyline is an 87 model
Has all receipts for a new crank angle sensor and radiator and all hoses etc.
Has 12 months rego
Brand new window tint, is darkest legal shade all round except back window is slightly darker but cops will never
notice!
OK, only faults - body is near on dead straight and no rust (had fun shocking a few panel beaters with how straight it is) but it just needs some paint. Being a typical 31 the clear coat has come off across the top. Side paint looks sweet, when you see it driving you don't notice the bad paint. All lights etc all work as well. The only other thing is the Air con popped and O-ring so it just needs the O-ring replaced and re-gassed and thats back in working order.
Interior is near on immaculate. Has a really nice black and grey interior (apparently rare so I am told). Only fault there are the drivers side door skin needs fixing (not bad at all, just some material come off close to front pillar). All carpets are perfect with no tares or holes or anything. Has about 265,000 on the clock. Got a folder full of receipts for it which if you took the car you could have. Oh yeah, and all the electric mirrors etc work.
The car has been a really good car to me, I don't really want to part with it but just brought myself a R31 Passage GT with an RB20DET and we can't fit all these cars at our house so it has too, so there is why I am selling it.
I want $3,500 for it.
Any enquiries feel free to email me [email protected]
https://www.sau.com.au/forums/topic/64255-wa-r31-skyline-manual/
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
