im sorry did i miss something, whats a charty? some sort of Indian festival or something?
on another note, the charIty cruise is on this sunday Sean, and it seems like you wont have a car, maybe you should take the ute or try and get someone to pick you up? lol, ok i'll stop being a cu*t!
id offer you to take mine for the day as i'll be stuck at work, but as its uninsured if anything happened to it i'd much rather i did it. gee there are a couple of us without working rides now huh? Myself, Richard and You. whats wrong with yours anyway?
https://www.sau.com.au/forums/topic/64298-charty/#findComment-1205822
Can I just say I was glad to see the 720 there, and I was glad to see you could hang onto it... It must be hard with so much power, yet so little weight over the back wheels :D
Great day out!
:burnout:
https://www.sau.com.au/forums/topic/64298-charty/#findComment-1207651
I had a diesel 720 4wd twin cab years ago, biggest POS I've ever owned. Wouldn't pull jesus off the cross. I had fully laden semi's overtaking me on hills.
Race_snooze - you legend.........................sorry I wasn't there [other things].
https://www.sau.com.au/forums/topic/64298-charty/#findComment-1208208
Sean, car is at Ed's as we speak, hopefully good news by about 1pm, i'll let you know.
Coool thanks, you make a big post of it, so as this one can die, not happy about my spell;ing at the start of the thread.
As for the 720 she is a beaut, L18 motor with a 180b 5 speed. Goes like a well I dont know any word to discribe her. She does me proud, starts first thing when I need her, I rev the shit out of her even with a load and she comes back for more. Almost uses the same amout of fuel as the 33, not, and she never uses oil or water, (that because there is none j/k) for now that is.
https://www.sau.com.au/forums/topic/64298-charty/#findComment-1208242
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
