BoOsTeD_RB26 Posted November 23, 2002 Share Posted November 23, 2002 Hey all, The gtr is going in for a 100k service pretty soon, and they said they have to pull the whole front end of the car off....to get at timing belts etc. Now if this were to happen....would it be easier installing things like HKS Adjustable Cam Gears (cheaper labour?).....instaed of having to do it later on? and are they a worth while add on? Will I get more driveability as well as power? anyone? Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/ Share on other sites More sharing options...
Warpspeed Posted November 23, 2002 Share Posted November 23, 2002 As yourself two questions. What is the current valve timing of your engine. What is wrong with it, and why will changing it improve anything. If you have a definite plan, fair enough. But just making something adjustable is not going to create a miracle. If you are doing it to dress up the engine, fair enough. They are a good loking piece of gear. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96486 Share on other sites More sharing options...
BoOsTeD_RB26 Posted November 23, 2002 Author Share Posted November 23, 2002 I just ask because I've read in a few magazines that they create more off boost power....and make the car more driveable on the street (more torque) and are a good piece of gear...and on some cars making another 20rwkw if they are set up properly and yes I rekon they look pretty sweet in the engine bay Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96496 Share on other sites More sharing options...
51jay Posted November 23, 2002 Share Posted November 23, 2002 Apparrantly you can adjust the timeing for more power up top or more torque lower down and boosting the torque is going to make it more driveable....and quicker. And , yes if the timeing cover is comming off that would be a good time to add it or them Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96539 Share on other sites More sharing options...
400HP Posted November 23, 2002 Share Posted November 23, 2002 What is the current valve timing of your engine. What is wrong with it, and why will changing it improve anything On any GTR the timing is not optimised for max power or even power or boost to be created early. And when theres been some light modifications like increasing boost etc theres even more potential. It's a proven result that vernier timing gears have given good results if tuned properly. There are dyno sheets to prove these and I'm sure many ppl on this forum have got good results. With twin cam engines you can alter the exhaust cam and the intake seperately. Most GTR's end up advancing the intake and retarding the exhaust. Of course the potential is only as good as it is tuned. Heres a dyno sheet of Mario's R34: http://www.exvitermini.com/pics/r34236d.jpg Note at the bottom the car made 10kw more @ the wheels even with a powerFC and AVCR and boost came on 800rpm earlier. The only downside I know of is a slightly lumpier idle. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96540 Share on other sites More sharing options...
Warpspeed Posted November 23, 2002 Share Posted November 23, 2002 Actually that makes a lot of sense. Especially retarding the exhaust cam. But as I said earlier you need a plan. You also need to spend money on tuning to get it right. There seems to be the mistaken impression around, that merely fitting adjustable cam gears will automatically make more power. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96547 Share on other sites More sharing options...
400HP Posted November 23, 2002 Share Posted November 23, 2002 I've been quoted tuning for this and its almost as expensive as the cam gears themselves because it needs to be done on a dyno and it might take a while. Depends where you go. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96550 Share on other sites More sharing options...
Warpspeed Posted November 23, 2002 Share Posted November 23, 2002 Yeah thats the problem. There is a lot of messing about, and it is time consuming. You also need to make absolutely sure there are no valve/piston mishaps as well. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96555 Share on other sites More sharing options...
BoOsTeD_RB26 Posted November 23, 2002 Author Share Posted November 23, 2002 so do you think it is a worth while thing to do.....or should I just ignore it and do something else? :confused: Can anyone give me an estimate on how much it would cost for the tune? They seem to be a pretty cheap add on if more torque is needed.....$360 from Takakaira Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96572 Share on other sites More sharing options...
400HP Posted November 24, 2002 Share Posted November 24, 2002 what are your current mods? if you're getting a whole lot of other work done I'd say jsut do it. It's prob gonna take a few dyno runs... maybe 5 or so... so maybe $200-$300 worth of tuning.... if you're getting other work done by them then maybe it will reduce your cost. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96780 Share on other sites More sharing options...
Clint32 Posted November 24, 2002 Share Posted November 24, 2002 if you are planning more mods in the future you could get them fitted and left at the standart timing which shouldnt cost you anything if they are doing the timing belt, then later you can get them dialed in. They are only worth doing if you have different mangement first as there will be more gains here Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96783 Share on other sites More sharing options...
BoOsTeD_RB26 Posted November 24, 2002 Author Share Posted November 24, 2002 engine mods are: apexi n1 zorst..with front pipes and dump pipes (no cat) k&n pod filters avc-r - 14 pound boost ...with this it made 220kw at the wheels...but it cut out due to the speed cut. ermm....and in the future i will be fitting a power fc, and maybe do a turbo upgrade.....depends on money.....but yeah...definately a power fc!!:uh-huh: Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96793 Share on other sites More sharing options...
fatz Posted November 24, 2002 Share Posted November 24, 2002 cam gears id only put them on if igot am shafts hihihihihihih shafts Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96927 Share on other sites More sharing options...
gtrken Posted November 24, 2002 Share Posted November 24, 2002 Originally posted by fatz cam gears id only put them on if igot am shafts hihihihihihih shafts WTF , ya gotta stop smoking then posting man:D Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96930 Share on other sites More sharing options...
BoOsTeD_RB26 Posted November 24, 2002 Author Share Posted November 24, 2002 I agree common fellas.....when the 100 000km service gets done....should I get the cam gears done or not.....or are they simply a waste of my money? Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96931 Share on other sites More sharing options...
gtrken Posted November 24, 2002 Share Posted November 24, 2002 Do it , then there in. Zoom mag a few issues ago had the settings to change the specs to or leave em std as clint32 said until you get it dynoed. Ken Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96933 Share on other sites More sharing options...
BoOsTeD_RB26 Posted November 24, 2002 Author Share Posted November 24, 2002 which issue was this...do u have it? u rekon they are worth the 400 odd bux? i guess i better just think about it some more thanks for the replys people..........any more advice? Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96948 Share on other sites More sharing options...
400HP Posted November 24, 2002 Share Posted November 24, 2002 Do it. It's a good mod. Zooms got an article on it and in HPI GTR special 2 it also has an article on it. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-96978 Share on other sites More sharing options...
Warpspeed Posted November 24, 2002 Share Posted November 24, 2002 Have to agree, stick them in and later when you have your FC and a few other goodies spend the money on a decent dyno tune. These two magazine articles, do they give before and after valve timing figures, and if so could someone please post them ? Stock factory 32/33GTR inlet cam opens 7 BTDC, closes 57 ABDC exhaust cam opens 63 BBDC, closes 7 BTDC (BTDC is correct) The stock settings have zero valve overlap. Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-97023 Share on other sites More sharing options...
fatz Posted November 24, 2002 Share Posted November 24, 2002 i dont have a problem im a drunk and i know it i still think "shafts" is funny though Link to comment https://www.sau.com.au/forums/topic/6447-hks-adjustable-cam-gears/#findComment-97101 Share on other sites More sharing options...
