Hi all.
Was cruzin in the city on friday night to pickup a mate and i got pulled over by some D's , they said " we have pulled you over as the legality of the modifictaion done to your car" then i have to got to the rocks where they were all waiting.
This is the 1st time ive been pulled over in this car.
And 4 those of you that have seen my car you wioll fiund it funny that this is all they got me 4.
1. 19" wheels when tyre placard says 16" - Fine $120
2, Chasis has been modified for the intercooler piping - Fine $60
then the minors
1. Tints to dark
2. boost guage in a pillar above steering wheel
3. www.skylinesaustralia.com sticker on wind sheild (yes thats right a sticker can not block the wipers)
thats it.
Lucky i know a few people in the buisness ( if you know what i mean)
Cant they just leave us alone?
https://www.sau.com.au/forums/topic/64546-got-defected/
i doubt the p-plates would have much to do with it, i would have thought the imported skyline models would be enough for the police to pull over and check when defect stations are around
but considering all the recent events involving p-platers and all related stories i suppose you could be right
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1208944
hey dude, yeah i got done in the same area - down at the docks in the rocks (had my whinge sesh in the general forum :) )
luckily mines only fairly stock and they got me for pod filter (frantically trying to find an airbox to fit the r33)
some of the cops were real pricks acting talking like i'd killed someone, but luckily the chick that was looking after me wasn't too bad.
Anyway bad luck man, hope u get it all done in time,
Catch ya
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211158
I drive around in a '97 series II with a standard Type-M kit, 18's with a GTR wing on the ass, I have not been picked up in it once yet, Its the huge GReddy stickers, 20 inch 'Bling bling stand-out-like-dogs-balls' chromes and ya 6inch exhaust tips that gets you pulled up. Cops are pricks, we all know that, why make yourself stand out to them, you dont need their attention cause it's bad news when you get it.
Getting defected is no big deal, it's not even about the fines, it's just the hassles of having to go back to get them cleared and shit.
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211373
Wheel Track
As a general rule, it is recommended you only fit wheels and tyres that are listed on the tyre placard or in the
owner’s handbook. These have been tested and proved for your car.
Sometimes the range of wheels listed by the manufacturer may appear to be limited. While it is recommended
that you only fit these wheels, the RTA does not oppose the fitting of wheels outside the range providing they are
safe for the vehicle.
An important requirement for all replacement wheels is that the wheel track must not be increased by more than
25mm beyond the maximum specified by the vehicle manufacturer for that vehicle.
Wheel Width
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the
vehicle can be fitted without the need to notify the RTA.
Wheel Diameter
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter
wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel
and tyre combination specified for the vehicle.
i was wrong in my previous post its 15mm not 10mm :P
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211664
Heres boys
had this discussion before
http://www.skylinesaustralia.com/forums/sh...ead.php?t=55039
by the way if you have any questions regarding Whats legal or illegal
ring the RTA Technical enquiries on 1300 137 302
FYI
I rang them yesterday and to my surprise i found out turbo timers are not illegal.
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1212013
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
