21 minutes ago, GTSBoy said:
It's just that it looks like it's all gone dry, but when you wet it the different materials darken differently and you can see the traces of the remaining guide coat, which are otherwise too thin to see when dry.
So does that mean i shouldnt be able to see any guide coat after wetting the area?
1 hour ago, Murray_Calavera said:
I'm confused, so your saying after blowing the area off, the guide coat is gone. But then when you wipe it down, the guide coat residue becomes visible again?
This isn't a trick question like there is guide coat residue on the rag that your wiping the area down with?
I cant see how once something is removed, it comes back when cleaning with wax and grease removed?
Yep correct. Or i guess maybe im wording it incorrectly. It's not as visible when blowing it off compared to wiping it with wax and grease remover.
I'll experiment with it again and post some photos
Edited by silviaz
3 minutes ago, silviaz said:
Ah maybe worth noting. I'm not using a compressor but a blower
100% invest in a compressor.
How many panels were you planning to paint? High quality paint rattle cans are super expensive and coverage is always depressingly low. Cost will add up very quickly.... I'd rather put the money into a compressor/gun then thousands of dollars worth of rattle cans (may sound crazy but at $50ish a can, you'll get into the thousands very quickly).
I'm keen to see a photo of what your talking about.
Please do. Also try the dry guide coat and compressor, keen to see how much of an improvement that is for you too.
  • Like 1
I got a compressor just dont use it. I'm fixing every panel. Full car is getting a respray.
I'm using dry guidecoat to not the spray. Similar to 3m stuff.
I'll be paying someone to spray paint it professionally, I'm just doing prep. No rattlecan jobs.
Yep I'll try get some photos up. I might actually have an example. I'll get back to you soon.
Oh i got a quickle example. Here you can see hardly any specs of guide coat then you can see in the other photo it's much clearer after spraying it with W&G remover.
I suspect i have a low spot here though
20250622_110920.thumb.jpg.802a84fa6ca37f82539b8dd2f90f8229.jpg20250622_110930.thumb.jpg.b71257b1ffcbafdc874b518a5ba3b634.jpg
Edited by silviaz
1 minute ago, silviaz said:
Oh i got a quickle example. Here you can see barely any specs of guide coat then you can see in the other photo
Thanks for the photo, those are pinholes in your filler :)
So yeah, guide coat is working as intended. If your going for a perfect finish, you'll want to fill those pin holes.
  • Thanks 1
11 minutes ago, Murray_Calavera said:
Oh god, you're doing all the hard work and none of the fun work :( do you have access to a garage you could paint it in?
I could paint it outside technically and i do have a garage spot just need to take out the other shitbox lol. Id rather do it myself for the experience but I don't think people in my household will be ok with the idea
What the. I thought putty removes pinholes from body filler. I didnt use any filler there i don't think only glazing putty. I also got the example ready.
As you can see? Guidecoat not visible and only visible after wetting the area.
They arent the regular pinholes i had before. Can primer fill this in? Edit: i had to really put my eye to the panel and can see the holes sort of.
Maybe i need to put 2 coats of putty instead of 1 after the first coat dries?
20250622_112102.thumb.jpg.1d29d5107f4ab25cf633ad982ff4bf70.jpg20250622_112118.thumb.jpg.d2dbb36c5fe18aa18eea49e58debe7d0.jpg
Edited by silviaz
Oh i think i made some progress! Just fixed another simpler dent and the guidecoat is gone even when the area is wet! The filler shape now resembles that of the dent if that makes sense so it's flat. The photos are before during and after
The only issue, i think i can feel a low spot lol.
20250622_113206.thumb.jpg.95f2afb9af40a1f61a6262535c173180.jpg20250622_113443.thumb.jpg.e16b7eb5b1427c34d5733f4eb20d7649.jpg20250622_113655.thumb.jpg.bc6a7ca90654176ac13f0963ece785a0.jpg
Edited by silviaz
I wouldn't do it outside, the contamination landing in the paint, the wind and a million other things will drive you crazy.
11 minutes ago, silviaz said:
only glazing putty
That's a way too big of an area to use your single stage putty on.
Pretend it's all filler and those pin holes appeared, you'd then use the putty on those pin holes.
They are still pin holes, hmm I expect a few coats of high fill primer could deal with those.
  • Thanks 1
Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).
Once the panel is flat, the guide coat will be gone :)
  • Thanks 1
Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it!
With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying.
Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course.
I feel silly now haha. ok I think I know what to do next. Thanks man!
Edited by silviaz
You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
  • Like 1
I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in.
I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
Edited by silviaz
Yep, correct.
The way you are using the putty is incorrect. Its meant to be used to fill those tiny pin holes, its not a body filler substitute.
I'd sand back all of that putty and do it again with body filler.
9 hours ago, Murray_Calavera said:
Yep, correct.
Yep will do. Thanks! I'm keen to do a next update.
  • Like 1
On 22/06/2025 at 10:36 PM, Murray_Calavera said:
Yep, correct.
Hey Murray, hope all is good. I took your advice and put the filler first then the putty. Seems like a much better result but i noticed there are still pinholes. I even had pin holes when i initially put the putty on the body filler.
Do you think it has something to do with my spreader being f*cked? I attached some images.
This is the intially body filler i sanded. No putty yet
Applying putty.
Final result after using wax and grease remover can see the pin holes.
20250628_153159.jpgI just noticed as i look at the putty application it looks wavy not sure if it's supposed to be like that or because of the spreader.
Edited by silviaz
More likely from tiny bubbles in the filler/putty. Maybe be less aggressive when mixing it. Perhaps invest in a vacuum chamber to pull the air bubbles out?**
**I don't know if this is a thing for body filler. I see hardcore epoxy makers degassing their mixed resin on the regular.
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
