i'm only talking of my experiences here, but ..
a. you dont need a fuel reg
You don't need a fuel regulator probably because you've got bigger injectors
He said he doesnt have the funds for them so he's going to need the FPR to bump up the fuel pressure to make 250rwKw.
Im also going down this route very soon with a 2535, standard injectors and HKS 256 EX cam
Probably would have been better with the inlet cam as well but hey, this is as far as I can go right now...
Not really interested in the injectors at the moment guys, I know you can get 240-250 out of the stock ones and i dont have a spare $700 to spend on something I dont really need.
So far it sound like i should go for:
 Z32 AFM, Fuel Reg & hi-flow tuned by Dave...
Is there anything that I have left out that I may need (excluding injectors :rofl:)
That’s the biggest understatement of the century... Theirs no point trying to up fuel pressure if your injectors can only flow stock amount.
No matter how much you change it via a FPR, It’s still only going to pump 380cc into the motor, and if you think you can get 240 - 250kw out of stock injectors go for it.
Because for the cost of $700 for an upgrade set, or for the cost of a re-build which you will be doing if you don't upgrade your injectors. I sure know which option I would go.
Theirs no cheap way when you get to that point. You can't expect to bolt on a bigger turbo, and not upgrade your fuel system. Because it just doesn't work like that.
You can increase the flow of the injectors by increasing the preasure, although I wouldn't go more than 10-15% more than stock preasure. This amount might just give you what your after without having to go to 550cc's.
lol bbq melted piston 6 :) (ages ago)
as long as people don’t do wat he did.. (run mass boost for to long) in a hot climate with almost stock everything cept avcr fmic n zorst
If you call 10psi Mass boost, when then I think you’re in trouble running 14psi. As that’s the biggest contradiction, Considering your running a stock Cooler, stock fuel system, stock computer, with a rb25turbo, (On a rb20) Running 14psi....... Ohh yer did I mention the Heat that your running it in !!!
Your setting a good example, just like your comment.
With a stock internal motor you can't expect to bolt on a bigger turbo, run more boost and keep the fuel system stock, it just not reliable. Bigger turbo = More Air, More Air, Needs more Fuel.
If you keep your injectors stock gunmetal 33, and you do the turbo upgrade.
I would like to see how long your car lasts until you are up for a re-build.
Hi guys, I need to clarify a few things here;
GCG ball bearing hi flow, no problems for 250 rwkw, best I have seen is 265 rwkw at 1.5 bar.
Upping the fuel pressure at the rail increases the fuel flow through the injector, but is isn't one for one. For a 10% increase in flow you need around a 25% increase in pressure. That's a lot more pressure (48 psi compared to 38 psi) so you need to make sure your fuel fittings, hoses, filter and clamps are capable.
Personally I would never aim for more than a 10% increase in flow, so 410 cc's is about the limit. Using the rule of thumb for a 6 cylinder, that's 410 bhp (306 kw) or ~ 240 rwkw. Best I have seen was 235 rwkw. That's using cleaned injectors with the highest flowing one in #6, the next in #5 etc. In a GTST this is due to #6 being at the rear, furthest from the radiator, not much air flow, radiated heat etc. Nothing to do with differential flow in the inlet system (like a GTR).
So you need to do the numbers, 1.5 bar = 22 psi + rail pressure 48 psi = 70 psi. Minimum you need a fuel pump that can supply 410 cc X 6 X 60 = 148 litres per hour at 70 psi. An R32 GTR fuel pump (used for the 265 rwkw) will do 190 litres per hour easily, as will a Z32, at that pressure. With reference to the attached tests on the Supra pump (make sure the part number actually agrees with yours) you can see that they are extremely voltage sensitive.......
At 12 volts they are below what I would consider a safe margin (155 litres per hour at 70 psi rail pressure). So if you haven't already done it, I would strongly suggest you run a dedicated supply to the pump from the battery via a relay. Use the standard wiring to switch the relay. That will get the voltage at the pump up to 13.8 volts (alternator output) and give you around 210 litres per hour, which should be more than enough.
OK on the Z32 AFM, although you might just get away with the standard R33 GTST AFM at ~240 rwkw. The Nismo "bolt on to the fuel rail" style of fuel pressure regulator will do the job for 70 psi ($149 from Nengun).
Bottom line GunMetalR33, the injectors will be the limiting factor in your plan, with around 240 rwkw being the most likely limit.
Hope that was of some help:cheers:
AAHHHGGMMM knowledge flexing....
Na just jokes, thanks for the great info. What happened to the attachment???
I personally would not bother with the highflow. go a jap brand, when it comes to it the price difference is not that much. I bought a gt-rs for $2800 from nengun, and sold my standard turbo for $450. which ends up costing me $2350 for my new turbo. GCG have them for like $2000 and its your standard one re-done so u save few humdred $$ for what? a highflow? i just personally dont think they are as good as a jap unit, but oppinions differ.
I'd agree that for the few extra $$$ it is worth going the Jap brand. in the case above $350 is very little!
So you guys just bolted the GTRS straight on, you didn't have to modify anything, buy anything extra or fabricate stuff? The GTRS fitted up exactly the same as the standard turbo? And it took you half a day to remove and replace, no special knowledge or tools required?
Then it made more power EVERYWHERE than when the engine was standard?
Then you took it out ot the drags in a full weight R34 GTT and it did an 11.9 at 120 mph?
There is more to a turbo than how much it costs on its own and the maximum power it makes at one RPM point. Personally, I take it all into consideration, look at what I expect from the car and then make a choice.
What sort of PSI are we talking to get the GCG hiFlow to produce the 240 mark you mentioned SK?
I have seen 240 rwkw at 1.2 bar, but remember boost is irrelevant, it is simply a measure of resistance to airflow. An example, the R34 GTT has cams and headwork. It makes 15 rwkw more at similar boost because the cams and headwork have removed the restriction, so it flows more air (to make more power) but the resistance (boost) is lower. I am sure the GCG ball bearing hi flow would make more than 1.5 bar if you stuck it on a restrictive/choked engine.
Guys, don't get me wrong, I am not picking on anybody or saying you have done it badly. There are more ways than one to skin this cat, I simply post up my way. That way readers can make their own choices.:)
PS; I don't place any importance in having a certain "name" brand product on my cars, I only care about how nice they drive and how fast they go. I can understand that some people want to have a "name" brand to impress people, but it's just not my thing.
lol bbq melted piston 6 :P (ages ago)
as long as people dont do wat he did.. (run mass boost for to long) in a hot climate with almost stock everything cept avcr fmic n zorst
You don't even know what boost he was running and how can you call,
Frontmount, full exhaust, pod all the usual stuff... STOCK ?
GunmetalR33,
I'd personally go bigger injector's for reliability, although you can push them to 250rwkw's as SK mentioned you have to change fuel lines and fittings etc to run that sort of pressure. You don't want a fire to break out in you'r engine bay!
I know what i'd do but its you'r decision , all i can say is you will notice the car will run, rev smoother with bigger injectors, same with bigger fuel pump.
Jun
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
