ummm.. i wonder whats gonna happen if u compair with same kw on both car??
and why compair HSV with NISSAN not with a NISMO??(e.g. NISMO 400R?)
anyway nice info u've provide... but i still like Skylines more than Holden... it just looks so much better...
cheers
  • Replies 350
k_hole
Registered User
Trader Rating: (0)
k-hole you sure you aint the reincarnation of skylinekiller or a buddy of sidewndr who have all joined on Feb 2005 just to have a look at how wrong all your comparison posts are.
and non of the holden or v8 supporters have answered my question about why do v8s need a 5.7L car with that much engine power to get a car to perform the same as a 2.6L car with 1/2 the power and its 10 years older.
The most enjoyable read ever was when they compared to R34 GTR to some New HSV in a speed mag i think. Both were equally modified (just a few small bolt-ons, boost and computer), and the T34 GTR beat the Holden in every aspect from rolling start to breaking etc... There is no argument that Holden has some catching up to do!
That was in Speed magazine I think yeah
The GT-R mauled the crap out of the GTS, and the GTS even broke some of it's drivetrain (I distinctly remember the 1 week old KAAZ LSD going snap)
But I'd have to say the most enjoyable read of the kind I've ever had was in Wheels magazine in 2002 I think, R34 GT-R V-Spec 2 Nur vs HSV V2 Coupe GTS
both dead stock
The Skyline pulled the Gen3 out the Monaro's arse
and I loved every word of it.
Maybe Skylinekiller should go read that article.
Thats easy, because GM can use light utility/truck engine as the basis of a performance engine to get cheap, reliable/durable performance. Throw in some alloy casting and the thing actually doesnt hurt sitting up the front of a sports car/sedan.
The V8 saves the hassle and complexity of turbocharges adding weight and heat, extra cooling / packaging requirements, adding to service intervals of the car etc etc.
And as for fuel economy etc etc. Think about it, if you put your boot into either, they both suck gas. Power is a result of flow thru the engine, and in turn the more power you make the more air you consume and accordingly the more fuel you need to use.
If you want to compare sports car to sports car, not sports sedan, compare the performance to a Corvette, an Ultima, a Robnell Cobra a TVR Cerbera. Lotus Espirit GT or another V8 powered Coupe/Sports car.:rofl: ...You start to realise that V8 powered sports cars are an expensive breed, even 2nd hand with the exception perhaps of a 928GTS
I cant believe this thread is still going...a think some Nissan drivers have blinkers just as big as Holden drivers:(
..and credit to Nissan the R32 GTR, they out foxed everyone in the old Grp A days. Holden were homolgating an ordinary sedan, Ford a shopping trolley, BMW a mass production rwd NA 4cylinder and Nissan go and BUILD a twin turbo, 4WD car from scratch to make the most of the rules and the class. They did the best job, but they did it with a blank canvas that was the R32 series, everyone else was throwing fibregalss and turbos/throttle bodies at road cars.
If you look at the job Nissan was doing with the DR30 and the R31 in the GrpA days, it just highlights the huge leap they took with the R32:thumbsup:
Thsi debate always ends in arguments, lol, i think thats why they are started, its as bad as talkign about who's girlfriend is better looking:)
all i'm saying is that this is a gimmick and its pretty funny
people like Roy have made some good posts so its not all a loss
why does nissan need 2.6L and mazda only need 1.3L then
just curious, ur arguing a point that makes u look even worse.
if you put a 1.3l next to a 2.6l and debate it all you like,
but then if i put the 1.3l mazda next to a 5l+ engine and compare the two it would make you look worse off, so you were better of not replying to anything
besides thats like comapring apples with oranges, pointless
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
