I have a few questions about the standard window tint on the Stageas that Im hoping some pros on here might be able to answer..
What is the exact reasoning for tinting all the windows bar the front driver and passenger windows? You can see it now on some of the new toyota four wheel drives as well. I know some of the reason was because the owner of the car in prestige vehciles usually was in the back but im certain a stagea wouldnt go that far...
Is this standard tint able to be removed at all or is it somehow part of the glass and not able to be removed because as far as I know under the new compliancing laws and removable tint is to be removed.
Is this tint actually darker then what is generally 'legal' in Australia (T35) but is it fine to have as it has been complianced with it?
Is it true that you can have the tint on the windows not including front driver and passenger and windscreen as dark as you want to as the car is a wagon?
Thanks :cheers:
https://www.sau.com.au/forums/topic/64869-stagea-window-tint/
I will try and answer a few of your Q's. One of the reasons for it not being on the front windows is that it is alot darker than the T35 and therefore at night it becomes hard to see things. The glass is what they call smoked glass and not a film over the window. My old man took his 96 imported Surf over the PITS in Darwin MVR and they sent him away to get it scraped off as it was darker than the T35, he told them that it was a factory smoked glass but they didn't believe him. so he humoured them by taking it to a window tint place and they wrote a letter advising them that it can't be removed. He took it back and he had no further problems. Here in Darwin you can only put as dark as you like if it is listed as a panel van.
Hope this helps
:cheers: ICE
Yup we are pretty lucky coz that tint is way darker than 'legal' - but as it isnt removable and factory standard it was approved for Stagea compliancing by DOTARS... but even with tinting here in Oz - I was told by several tint places that you are allowed the max legal dark tint on any rear side windows, but one shade lighter on rear windscreens and side front windows, and no tint on front windscreen.
When I took mine over the pits they had 3 blokes there trying to lift the tint off.. They aggreed that it was in the glass from factory so they passed me :cheers:
They also tested the darkness, the tint on the rear doors let 11% light through !!! the darkest tint you can go must let 30% light through.. Big difference.
J
Hehe yah for factory tint! Thanks for the good replies there guys, looks like its all legit now.. Funy to see a few people here have had problems with it for compliancing :cheers:
On the subject of one shade lighter on the rear windscreen mine does seem to be a lighter shade then the others, is anyone elses like this? Would it be that it wasnt smoked glass on the rear windscreen?
The rear windscreen is the same issue, it can't be too dark because you have to be able to see out of it. Mine came with a film tint on it, but it was very light, and had the very cool sticker of "A prestige touring wagon that is functional yet comfortable" i have since had the tint removed and darker tint installed on both front windows and the rear hatch window
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • You can trust Rezz!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
