  • Replies 44
Does anyone know where I could find some r34 gtt headlights. I just imported my 34 and they disconnect the xenons and change the inside of the lights so you can't put them back in for compliance reasons.
They've changed the inside of them??? How so?
I thought they only converted it into the H1. You can always buy the aftermarket Xenon Kit and use it in yours.
Btw, got a pic of the parts they removed for the compliance?
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1216431
If you were in sydney i could convert yours to halogen keep the globes and the balasts , then convert back after you comply the car .
I was looking for a set for mine , Nissan sell them about $1000 for the 2 .
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1217432
sorry is that $1000 just for the headlights or will i still have to get extra stuff to get the xenons working
1000 is for halogen lights .
I thought you wanted to convert your xenons to hal for compliance .
If you want xenons from Nissan , forget it they are to expensive .
The best thing for you would be to go to aftermarket conversion kit now .
You will find that they have taken the balasts out , ( they are sopose to destroy them , probably kept them ) and cut the clobe fitings so they can fit the halogen globes in them .
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1217774
Man, why can't they just leave those stuffs alone.
I'm sure the luxury euro cars have HID Xenon fitted in the car. How come that is permissable and not on ours?
They need to be self adjusting and have washers to comply with adr .
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1217777
Guest qtvinsta
I'd be interested to get my GTT changed back to Xenon headlights as well.
I've been told that they are removed because they aren't self adjusting (levelling)... as you already know, we have a dial to adjust the angle from inside the car but it's not self adjusting.
Is this true, i don't know.... does anyone have an Australian delivered car that comes with Xenon? are they self adjusting?
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1225189
If its already complied they probably took the balasts out and destroyed the globes so you are going to have to get another kit for it , not cheap .
they have to be self adjusting and self cleaning to comply with adr .
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1225685
  • 3 weeks later...
Ok got a price for genuine parts. For the headlights it's $690 each but with xenons it $2000 each. Is it possible and would it be cheaper to get a aftermarket xenon kit ?
I've had no luck getting second ones, I only got one reply so far from e-mails and the best i got was 1 used right hand light with xenon for $1000. does anyone know some good wreckers?
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1251821
I am looking for Halogen headlights to buy or borrow hehe for compliance and then registration and then i will put the xenons back in. any help welcomed whether it be lending me some or telling me where to buy or selling me second hand ones cheers, obviously they won't be on there for long.
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1252482
  • 1 month later...
I am getting my halogens direct from nissan and then getting them put in for compliance but leaving the Xenons intact
https://www.sau.com.au/forums/topic/65012-r34-headlights/#findComment-1324504
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
