hi all,..
i've noticed that some r32's have a blue background on their RPM, Speedo, oil, temp, boost gauges on the instrument cluster and its not those illuminicent types. and its not the bulbs ... its clearly the background with the klms, rpm reading etc..
my factory is black background.. and definately the one i saw was factory as well .. maybe a GTR cluster?
does anyone know if the above can be purchased somewhere? or is it something done aftermarket?
https://www.sau.com.au/forums/topic/65120-rpm-speedo-tachos-blue/
I did about the same as you, but mine were really dodgy~~
but have a look anyway.
Andy
They look alright... can't really tell how bright they are from the photo. I'll see if I can get a shot of mine.. I think they came out really well. I also did the centre console gauges on mine.
It should be the same but you should check somebody's first before getting a new one.
I might have one lying around if interested.
dude where u at? can i check them out ??
let me know!
that means i have to wind back the clock on urs ....how much k's does it have?
cheers!
I'm in Syd. I'm not sure on K's but you might be able to just use plastic or the blue film. I'll try to have a look at it tonight if i dont forget.
sweet ass .. let me knw how u go ... .. i think we can just remove the plastic fins but sometimes the labels (numbers etc) are on the hard plastic of the thin plastic fin (blue)
check it outz and let me know ..
or is it better juzz to get the nismo 300+ klms cluster?
how much do they go for?
I found that the early guages dont plug straight in, the tracks on the back are a bit different. But it's easy enough to swap the blue faces onto the later dash.
thanks dude for the info ..and everyone 1 else who contributed ..
i might just have to source them out somewhere ... i wonder how much the cluster is?
Okay to tell you the truth... they are not bright enough for me, I can't see what speed I am going at most of the time... probably will put more drilling and LEDs in later on.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
